ᐅ How can I clean Malm furniture without using chemicals?
Created on: 5 Jan 2020 10:23
Male3
Male3
5 Jan 2020 10:23
Hello everyone, I hope to find some experts here who can help me. I own several IKEA Malm furniture pieces that I would like to clean without using chemical cleaning products. These items have a wooden construction with a coated surface, and I’m concerned that harsh cleaners might damage or cause the finish to fade over time.
I am especially interested in how to gently but thoroughly clean Malm dressers or desks with white or light-colored surfaces without relying on conventional chemicals that can be harmful to the environment or pose health risks.
What household remedies or natural cleaning methods would you recommend? Are there specific techniques that have proven effective, even for stubborn stains or dust? I would also appreciate tips on how to maintain the surface so it stays looking new for longer.
Thanks in advance for any helpful advice!
Elodie
5 Jan 2020 10:44
Male3 schrieb:
I'm especially interested in how to clean Malm dressers or desks with white or light-colored surfaces gently but thoroughly, without having to rely on conventional chemicals.
Hey! I clean my Malm furniture using a simple homemade remedy: a mix of warm water and a splash of vinegar. Don’t use too much vinegar, or it can leave an unpleasant smell! Just dampen a soft cloth, wring it out well, and wipe gently in smooth strokes. This helps remove dust, fingerprints, and even light stains. 🙂
Sometimes I follow up with a dry cloth to avoid water spots. This method works great, and I find it refreshes the surface a bit without the need for harsh chemicals.
I like it when things are practical and environmentally friendly. Give it a try!
kla69
5 Jan 2020 12:05
I would like to comment on this topic in more detail, especially because caution is advised with coated furniture such as the Malm series from IKEA. The surface is usually made of a melamine resin coating, which is relatively resistant to moisture and light mechanical stress, but can still be damaged if not treated properly.
Male3 schrieb:
I’m concerned that harsh cleaners could damage the surface or cause it to fade over time.
This concern is justified. I recommend avoiding pure vinegar essence or stronger concentrations, as they may gradually damage the surface. A better option is a mixture of lukewarm water with a mild dish detergent (for example, a palm oil-free, pH-neutral product). Apply this to a microfiber cloth, wring it out very well so the surface is only slightly damp. After cleaning, it’s best to immediately dry with a clean, dry cloth to prevent water spots.
If stains are stubborn, you can carefully use a cleaning eraser designed for laminate and plastic surfaces, but always test on an inconspicuous area first. Also, never use abrasive cleaners or coarse sponges, as they can scratch the surface.
Care: I do not recommend polish, as these coatings are generally not made for it and the product can clump or leave residues on the surface. Simply cleaning regularly and drying right away is the best method.
PEDRO40
5 Jan 2020 14:18
I can fully understand how important it is for you to avoid chemicals while still achieving effective cleaning. I felt the same way when I cleaned my Malm drawers for my children’s bedroom furniture.
Elodie schrieb:
A mix of warm water and a splash of vinegar
I would like to add that it’s essential to pay attention to the amount of vinegar used. Too much vinegar can actually cause damage and, as you mentioned, has a very strong smell.
I have also had good results with a baking soda paste: simply mix baking soda with a little water and gently apply the paste with a soft cloth. Avoid scrubbing too hard to prevent damaging the finish. This method effectively removes dust and minor discolorations. Afterwards, wipe thoroughly with water and let it dry.
Besides cleaning, I’m also interested in sustainable care, so I avoid harsh products to keep the furniture in good condition for as long as possible.
In my view, the key is to prevent dust from settling in the first place, making everyday cleaning much easier.
tetan
5 Jan 2020 15:02
For Malm furniture, the only effective method is to wipe with a slightly damp microfiber cloth. For stains, use a baking soda paste or mild soap, then wipe thoroughly. Do not scrub!
kla69
6 Jan 2020 09:37
PEDRO40 schrieb:
I have also had good experiences with a baking soda paste
That is very good advice, but I would recommend testing the paste carefully first, as baking soda’s fine grain can have a slightly abrasive effect. Always test on sensitive melamine surfaces beforehand!
tetan schrieb:
For stains, baking soda paste or mild soap flakes
Soap flakes are also a mild option. I would recommend using pure liquid soap flakes rather than strongly perfumed or colored varieties.
A further note on care: After cleaning and drying, occasional wiping with a very lightly oiled cloth (e.g., heavily diluted linseed oil) can help with some wooden furniture. However, this is not necessary for the melamine surfaces of Malm furniture, as the material does not require oiling.
