ᐅ How can I clean IKEA Metod kitchen fronts in an environmentally friendly way?
Created on: 10 Oct 2022 08:23
Kenson
Kenson
10 Oct 2022 08:23
I recently purchased an Ikea Metod kitchen and now want to make sure that cleaning the fronts is done as environmentally friendly as possible, without damaging the surface or colors. Since the fronts are often made of coated material, I am wondering which cleaning agents or home remedies work best to remove grease, fingerprints, and other typical kitchen dirt without using chemical pollutants.
Does anyone have experience with how to clean Ikea Metod kitchen fronts most effectively and sustainably? Are there any specific methods or tips for cleaning with simple ingredients like vinegar, baking soda, lemon juice, or other eco-friendly products?
I look forward to your recommendations and hope for useful practical advice!
gregto
10 Oct 2022 09:52
Hello Kenson,
I think your question about environmentally friendly cleaning of the Ikea Metod kitchen fronts is very good and important. Especially with coated surfaces, it is essential to use mild cleaning agents to avoid the fronts becoming dull or damaged.
For daily cleaning, I usually recommend a soft microfiber cloth combined with lukewarm water. Many stains can be easily wiped off this way. If this is not enough, a solution of water and a bit of baking soda (sodium bicarbonate also works) is very effective, since baking soda is mildly alkaline and can dissolve grease without being harsh.
Simply mix one tablespoon of baking soda into one liter of water, soak the cloth in the solution, and wipe gently. Afterwards, rinse the cloth and wipe again with clean water to remove any residue. Vinegar or lemon juice are less suitable because their acidity can potentially damage the surface—especially on white or matte fronts.
You should definitely avoid aggressive cleaners or abrasive agents, as these can damage the protective coating.
In general: it is better to clean more frequently and gently than to clean rarely with strong products.
If you have any further questions, feel free to ask!
Blavin
11 Oct 2022 11:47
To complement the previous tips:
IKEA Metod kitchen fronts usually have melamine-coated or lacquered surfaces. These are fairly durable but sensitive to solvents and strong acids.
I recommend the following method for an environmentally friendly yet effective cleaning:
- Use a soft cloth, such as a microfiber cloth, that won’t scratch the surface.
- For greasy stains, a mild cleaning solution made of water and a few drops of a pH-neutral dish detergent works well.
- For tougher stains, you can apply a paste made from baking soda and water gently with the cloth.
- Avoid vinegar or citrus acids, as these can damage the protective coating over time.
- Always wipe down with clean water afterward to completely remove any cleaning residues.
- Dry the surfaces with a soft cloth to prevent water spots.
In my opinion, this method offers the best balance of environmental protection, sustainability, and material care.
For visible marks like felt-tip pen stains or similar, an eraser often works well without the need for chemicals.
GALEO4
12 Oct 2022 18:03
gregto schrieb:
Vinegar or lemon is less suitable because the acid can potentially damage the surface
I see it differently. Of course, acidic household remedies need to be used carefully, but in my experience, they work very well, especially for cutting grease.
A vinegar-to-water ratio of 1:3 in a spray bottle is my go-to solution for the kitchen – and the fronts of my Metod cabinets are still flawless after years of use.
Naturally, you should always wipe down with clean water after treatment to avoid long-term issues. I think it’s important to put the “fear” of household remedies into perspective and not rely solely on baking soda.
Another point: biological cleaners with enzymes can also be very effective and environmentally friendly, often outperforming many traditional household remedies.
So, if you prefer to be conservative and cautious, stick to baking soda and water, but there are definitely several ways to achieve the goal.
Joe52
13 Oct 2022 07:14
GALEO4 schrieb:
Vinegar water mixed in a 1:3 ratio (vinegar to water) in a spray bottle is my go-to cleaner for the kitchen
I can confirm that this mixture works well, although I was initially skeptical about the potential effects on Metod fronts, especially since I have young children at home and prioritize using non-toxic materials.
What helped me is paying attention to subtle signs: so far, I haven’t noticed any slight discoloration or dull spots when applied gently.
In my opinion, it’s important to wipe very gently without applying too much pressure — often, this results in an even better cleaning outcome than using baking soda.
What also surprised me is how quickly dirt builds up despite regular cleaning — the only solution is a consistent and gentle routine.
Thanks to everyone here who openly shares their experiences! I feel well supported in this community.
