ᐅ What is the best way to clean Ikea Brimnes furniture when you have pets?
Created on: 21 May 2023 07:43
TAANBEN
Hello everyone, I have Brimnes furniture from Ikea at home and I also have two pets (a cat and a dog). Since the furniture mostly consists of coated wood surfaces, I’m wondering about the best way to clean them to protect the furniture while effectively removing pet hair, possible dirt, or scratch marks.
Does anyone here know good methods, perhaps specific cleaning products or home remedies, that help keep the surfaces clean over time and also prevent pet odors? It would be great if you could also point out any potential risks when cleaning, especially concerning pet hair and possibly harsher cleaning agents. Thanks in advance!
TAANBEN schrieb:
Does anyone here know effective methods, maybe specific cleaning products or home remedies, to keep surfaces sustainably clean and also prevent pet odors?I really appreciate how thoroughly you covered the topic of pets and furniture. I’m in a similar situation, and it has helped me to use gentle cleaners that are biodegradable and free from harsh chemicals.
One little tip from me: I mix some water with a splash of lemon juice and a very small amount of mild dish soap. This solution is not only gentle but also has disinfecting properties and helps neutralize odors.
Also important: regularly ventilate the rooms and avoid heating them too much to prevent odors. I often notice that dry heating air tends to intensify smells.
Based on my experience, I’m adding a practical guide specifically for Brimnes furniture when you have pets:
1. Preparation:
- First, remove loose dirt with a vacuum cleaner or a soft brush.
- Use an anti-static cloth to help prevent pet hair from sticking.
2. Cleaning:
- Mix lukewarm water with a drop of neutral pH dish soap.
- Dip a microfiber cloth into the solution and wring it out well so it is damp but not wet.
- Wipe the furniture surfaces gently using circular motions.
3. Stain removal:
- For stubborn stains, carefully test a vinegar solution (1 part vinegar to 4 parts water) on an inconspicuous area.
- Alternatively, special cleaners designed for melamine-coated surfaces also work.
4. Aftercare:
- Thoroughly dry the surfaces with a clean, dry cloth.
- Avoid standing moisture to prevent damage and swelling.
5. Protection:
- To reduce future scratches from pets, consider using protective film or decorative elements as a barrier.
This multi-step approach has proven effective in maintaining both the surface and hygiene at a good level.
1. Preparation:
2. Cleaning:
3. Stain removal:
4. Aftercare:
5. Protection:
In summary, I see it this way:
- Brimnes furniture is generally well protected against moisture, but it does not have solid wood surfaces. Therefore, harsh cleaners and abrasive cleaning tools should be avoided.
- Microfiber cloths combined with mild, pH-neutral cleaners are the best way to effectively remove pet hair without damaging the surface.
- Vinegar is a reliable home remedy for odors but should be used sparingly and diluted to prevent potential damage.
- To combat odors, it is worthwhile to ventilate the room well and use odor-absorbing substances like baking soda.
- For pets that scratch or chew on the furniture, protective films or special covers can significantly extend the furniture’s lifespan.
I hope this summary helps you care for your Brimnes furniture in a pet household.
