ᐅ How do I clean the drawer slides of Ikea BRIMNES drawers?
Created on: 29 Apr 2019 16:33
MATHIASM53
MATHIASM53
29 Apr 2019 16:33
Hello everyone, I recently bought an Ikea Brimnes piece of furniture with drawers that feel a bit stiff. My specific question is: What is the best way to clean the drawer runners of the Ikea BRIMNES series without damaging their functionality or the material? I understand that these runners are usually made of metal, possibly with plastic sliders. Are there any special cleaning or lubrication products you would recommend? Also, do I need to remove the runners for cleaning, or can this be done with the drawers still installed? I want to avoid the runners rusting or sticking. Thanks in advance for your tips and experiences!
Kinbu
29 Apr 2019 17:22
Hello Mathias, that is a very good and precise question. To properly clean the drawer slides of the Ikea BRIMNES, you can proceed as follows:
- First, pull the drawers completely out of the furniture. This is important to allow good access to all areas of the slides.
- Use a dry or slightly damp cloth to remove dust and coarse dirt. Avoid wet cleaning to prevent moisture damage.
- If stubborn dirt or old lubricant residues have built up, you can apply some isopropanol (cleaning alcohol) to a cloth and gently wipe the slides. Be careful not to damage the plastic parts.
- After cleaning, I recommend using a special lubricant designed for drawer slides or a silicone-based spray. These are durable and maintain the slides without leaving residues.
- Important: Do not use grease or oil, as they can smear and attract dust.
- The drawer slides do not necessarily need to be removed; as long as you take the drawer out, you can easily reach the slides.
This way, you protect the mechanism, ensure smooth drawer operation, and avoid damage caused by improper maintenance. Hope this helps!
Ryker66
29 Apr 2019 18:05
Kinbu schrieb:
The drawer slides do not necessarily need to be removed; if you take out the drawer, you can easily access the slides.
Exactly. Remove the drawer, clean it with a dry cloth, then spray with silicone lubricant. Done.
difepeo
30 Apr 2019 10:48
MATHIASM53 schrieb:
Are there any specific cleaning and lubricating products you would recommend?
I find it interesting that often only maintenance with oils or sprays is recommended, without considering the material compatibility and long-term effects in detail. The BRIMNES drawer slides from Ikea do not seem to be standard runners but rather simple metal-plastic constructions. Therefore, it is important to check whether silicone spray or other lubricants not only improve smoothness temporarily but don’t cause sticky residues after a few weeks that are even harder to clean.
One might also consider whether occasional cleaning with a mild degreaser like isopropanol would be sufficient, possibly without applying oil afterward if the slides are not too stiff. Too much lubricant can attract dirt and, over time, cause more harm than good.
I would like to hear about other users’ experiences who have been using their BRIMNES drawer slides for years. Who among you has long-term experience, and how do you handle cleaning and maintenance?
