ᐅ How do I maintain Ikea Hemnes furniture under heavy use?
Created on: 24 Feb 2024 08:37
nonsimon
nonsimon
24 Feb 2024 08:37
Hello everyone, I have several pieces of furniture from the Ikea Hemnes series in my apartment, mainly made of solid pine wood. Since these pieces are used quite heavily—sometimes as storage and sometimes as seating—I’m wondering how to best care for the Hemnes furniture to protect the surface and minimize scratches, dents, or discoloration, or at least treat them properly if they occur. I understand that the wood is either untreated or lacquered, but I would like to know which specific cleaning and care products are recommended, whether regular application of a special oil or wax is necessary, and how to best prevent and repair everyday damage. Perhaps someone has special tips for heavily used furniture from this series? I would appreciate advice that supports both the appearance and durability of the furniture.
fiman
24 Feb 2024 09:15
For Hemnes furniture made of pine wood, I always use a mild wood oil that protects against moisture and enhances the natural appearance. For small scratches, fine sandpaper followed by an additional treatment with oil helps. Avoid using harsh cleaners!
KUDAISY
24 Feb 2024 10:44
I’m happy to provide you with a structured care guide for your Hemnes furniture, especially under heavy use:
- Cleaning: Avoid water stains by wiping quickly with a soft, slightly damp cloth. Use pH-neutral cleaning agents and a cotton cloth instead of microfiber.
- Maintenance: For the oiled pine surfaces, I recommend a special wood oil (e.g., linseed oil or hard wax oil, depending on the finish). Apply thinly, let it absorb, then wipe off any excess.
- Damage: You can gently sand out minor scratches with sandpaper (grit 240-320) and then re-oil the area.
- Prevention: Use felt pads under items, avoid sharp-edged deposits, and prevent direct sunlight exposure to avoid discoloration.
A common mistake is regularly using too much water, which can penetrate the wood and cause swelling.
GALEO4
25 Feb 2024 14:22
KUDAISY schrieb:
For oiled pine wood surfaces, I recommend using a special wood oil (e.g., linseed oil or hardwax oil, depending on the finish). Apply thinly, let it soak in, then wipe off any excess.
I hear that a lot, but seriously: isn’t it more of a marketing thing that you constantly have to reapply oil or wax? Furniture like Hemnes is cheap, meaning the surface is usually only lightly protected and doesn’t hold up well. I would recommend a surface protection with a good paint instead – it looks better and lasts longer, rather than constantly covering up dents with oil.
Lucien
25 Feb 2024 16:38
For the care of IKEA Hemnes solid pine furniture under heavy use, I recommend a well-founded, practical approach:
- The Hemnes series is usually sealed with clear lacquer or treated with oil. The finish provides protection against moisture and mechanical wear.
- For lacquered surfaces, regular cleaning with a mild, alcohol- and solvent-free cleaner is sufficient.
- Avoid leaving water standing to prevent swelling.
- For oiled surfaces, specialized wood oils are advisable; these not only nourish the wood but also protect against drying out and fine cracks.
- Damage such as scratches or small dents can be treated on oiled surfaces by lightly sanding the affected area and reapplying oil.
- Repairs on lacquered furniture require specific touch-up pens or polishes.
These recommendations are based on the composition of Hemnes furniture and are supported by scientific research in wood care.
nonsimon
26 Feb 2024 07:52
GALEO4 schrieb:
Isn’t it more of a marketing issue that you constantly have to reapply oil or wax?
I find GALEO4’s comment interesting and wonder how practical it really is to maintain Hemnes furniture with oil in everyday use, especially with heavy wear. Are there any experiences regarding how often the oil should actually be applied to provide noticeable protection without requiring too much maintenance effort? Also, I think it’s important to consider whether a lacquer finish might be a better alternative if you want to minimize upkeep.
