ᐅ How can I build Ikea Metod cabinets so they are stable and durable?
Created on: 22 Aug 2021 19:23
samet65
Hello community,
I am currently planning to outfit my home with Ikea Metod cabinets and want to build them as sturdy and durable as possible. My specific question is: how can I construct Ikea Metod cabinets so they remain stable and functional even under heavy use and over several years?
I am familiar with the basic assembly instructions, but I am particularly interested in tips that go beyond the standard assembly, such as reinforcements, additional fastening methods, suitable tools, or materials I can use to increase stability.
Does anyone have experience or recommendations on how to make the cabinets as robust as possible, for example in heavily used kitchens or in large kitchen layouts? What mistakes should be avoided?
Thanks in advance for your detailed advice!
I agree with angel: install strong back panels.
I would also recommend fastening the individual cabinets to each other with screws. This prevents them from pulling apart over time.
Additionally, if possible, attach the cabinets to the wall at multiple points, not just at the top. This greatly increases stability.
liRaul49 schrieb:
I would recommend connecting the individual cabinets to each other with screws.That is actually a good tip. Screwing the cabinets together prevents movement. Ideally, of course, the materials should be generally upgraded.
Back to the topic of back panels:
Many underestimate how much stability comes from a rigid back panel. Replacing the original with a 6 mm (1/4 inch) plywood panel gives the whole assembly almost a cabinet-like character, as you would get from a professional carpenter.
However, I remain skeptical whether the effort is worth it if inexpensive particleboard is used in the end.
jotisi schrieb:
Again on the topic of back panels:The most important thing is that the cabinets are perfectly aligned and not installed crookedly. When that is done correctly, it also forms the foundation for durability with Metod.
jotisi schrieb:
Whether the effort is worthwhile when cheap particleboard is used in the end.It should not be forgotten that Metod is a system designed for users with different requirements. Those wanting greater stability can achieve a lot through reinforcements and additional options. Overall, it is a good compromise between cost, function, and customization.
However, if you want to heavily upgrade, you should seriously consider professional cabinet making instead. For most kitchens, Metod with the modifications mentioned above is very well suited.
