ᐅ What is the best way to clean Malm furniture when it is dusty or dirty?
Created on: 4 Apr 2020 08:37
lomireo
lomireo
4 Apr 2020 08:37
I have several Malm furniture pieces from IKEA in my living room, which I regularly want to clean from dust and dirt. Since the surfaces are usually lacquered or melamine-coated, I’m wondering what the best way is to clean them without leaving unsightly marks or causing damage.
In particular, I’m interested in: Which cleaning product is best suited for everyday dust and tougher stains? Should I use microfiber cloths or regular rags? And what about moisture — is it better to wipe the furniture with a damp cloth or just dust it dry?
If anyone has experience with Malm furniture and can share practical advice, I would really appreciate it. The cleaning should be effective but also gentle, so the surface remains in good condition for a long time.
Best regards!
mesila
4 Apr 2020 09:44
Hello lomireo,
good that you ask so precisely – Malm furniture is indeed somewhat sensitive to incorrect maintenance. Here is a small guide on how to clean your Malm furniture optimally:
1. Dry cleaning: For regular dust, I recommend microfiber cloths because they capture dust very well without scratching. Avoid paper towels, as they can leave small fibers behind.
2. Damp cleaning: For light dirt, a slightly damp microfiber cloth works well. Use lukewarm water without additives. Lightly spray the cloth, never directly onto the furniture.
3. Cleaning agents: Avoid harsh household cleaners, especially those with solvents or alcohol. Mild dish soap can be used, but sparingly to prevent residue.
4. Stubborn dirt: For this, you can use a mixture of lukewarm water and a few drops of dish soap. Apply it with a soft sponge and then wipe off with a damp cloth to remove soap residues.
5. Drying: It is important to dry the surface after cleaning to avoid water spots.
Common mistakes: Applying cleaners directly, using too much water, or abrasive cleaners.
If you want, I can also give you tips on how to avoid scratches and fix minor blemishes.
Good luck!
besau
4 Apr 2020 10:18
mesila schrieb:
For regular dust, I recommend microfiber cloths because they capture dust very effectively without scratching.
Exactly, microfiber cloths are essential.
For damp wiping: use a cloth slightly moistened with water only, do not spray cleaning product directly onto the furniture.
I usually use warm water and rinse the cloths thoroughly after use.
refinar
5 Apr 2020 07:56
I would like to add some tips, as I own Malm furniture myself and proper care of melamine-coated surfaces is essential.
First, always remove dust with a dry microfiber cloth to prevent scratches.
lomireo schrieb:
Which cleaning agent is best for everyday dust and tougher stains?
For stubborn stains, I use a mild dish soap diluted in water (about 1 drop per 500 ml (17 fl oz)) and then wipe with a well-wrung cloth. Never leave it wet! Prolonged moisture can cause the surface to fade or warp.
mesila schrieb:
Lightly spray the cloth, never spray directly on the furniture.
This is very good advice since spraying directly on the furniture can be absorbed and leave stains.
Finally, I recommend avoiding cleaning the furniture in direct sunlight or near radiators, as this helps maintain the surface durability.
One more tip for dust prevention: change your microfiber cloths regularly and wash them without fabric softener, as softeners build up in the fibers and reduce their absorbency.
Best regards!
JORDON
5 Apr 2020 14:26
Hey everyone 🙂
In my opinion, when it comes to Malm furniture, it’s better to clean briefly and often rather than doing an intense, overly wet cleaning session infrequently.
Dust is best removed with a soft microfiber cloth, gently—almost like softly brushing with cotton wool—to avoid scratches.
If the dirt is a bit stubborn, the cloth can be slightly damp, but never soaking wet. This way, the finish stays happy and keeps its shine for a long time.
Here’s another tip: don’t set your radiators too high—no one likes dry air with dust settling on their furniture 😉
By the way, I don’t use any chemical cleaners, just water; nature usually does the job.
Give it a try—cleaning can be that simple 🙂
nubar
6 Apr 2020 12:07
In addition to the very good tips provided so far, here are some precise recommendations:
Malm furniture has a melamine coating, which makes the surface resistant to water but not completely waterproof. Therefore, any moisture should be wiped away as quickly as possible.
For tougher stains, I recommend using warm water with a few drops of a neutral dishwashing detergent. Afterwards, wipe the furniture with a damp cloth—meaning not dripping wet—and immediately dry and polish it with a dry microfiber cloth.
You should avoid abrasive cleaning agents, alcohol-based cleaners, acetone, or other solvents, as these can damage the surface.
A note on storage and ventilation: rooms with high humidity or direct sunlight can cause the surface to age more quickly.
If you clean regularly and carefully, you will enjoy the quality of your furniture for a long time.
