ᐅ What is the best way to clean Ikea Hemnes furniture when there are children in the house?
Created on: 29 Jul 2022 08:13
O
Ottfried1O
Ottfried129 Jul 2022 08:13Good morning everyone, I’m currently facing a challenge and would appreciate your experienced advice: What is the best way to clean the Ikea Hemnes furniture when there are children in the house? In our case, this mostly involves dirt from spilled drinks, fingerprints, and occasionally small snack stains. I want to keep the care routine as gentle as possible since the material is said to be delicate, but also hygienic and free from harmful substances because of the children’s contact. Does anyone have a tried-and-true routine or special cleaning products that work well without damaging the furniture? I’m grateful for any tips, including practical tricks for removing stubborn stains.
Ottfried1 schrieb:
In our case, this often involves dirt from spilled drinks, fingerprints, and occasional small snack stains. That sounds like a typical day with kids! My advice: start by wiping with a soft, slightly damp cloth before the mess dries. For tougher spots, a mild soapy solution (preferably with baby shampoo or a neutral hand soap) works really well, as it won’t damage the surface and leaves a pleasant scent. Just wipe again with a clean cloth and dry thoroughly. This way, the Hemnes will stay looking great for a long time.
Of course, avoid using too much water, as wood doesn’t respond well to excessive moisture. Oh, and if a marker pen accidentally leaves a mark—don’t worry, a damp cloth with a little dish soap often removes it. Good luck, and don’t let your Hemnes suffer! 😉
To clean the IKEA Hemnes effectively and gently in a household with children, I recommend the following approach:
- Avoid using aggressive cleaning agents that contain solvents or alcohol, as these can damage the surface.
- For stain removal, use a soft microfiber cloth dampened with lukewarm water and a small amount of pH-neutral soap.
- After cleaning, wipe the surfaces immediately with a dry cloth to minimize moisture and prevent warping.
- For very stubborn stains, cleaning with a mixture of water and mild vinegar is recommended, but apply only briefly and wipe immediately afterward.
- Fingerprints can be easily removed with a lightly dampened cloth.
Regular cleaning is important to prevent dirt buildup. This helps keep the wood protected and hygienic.
A small guide for cleaning Ikea Hemnes furniture in homes with children:
- Step 1: Gently remove dust and loose dirt with a soft, dry cloth.
- Step 2: Prepare a mild cleaning solution (e.g., a few drops of pH-neutral dish soap in lukewarm water).
- Step 3: Wipe the surface with a well-wrung cloth. Be careful not to leave excess moisture on the surface.
- Step 4: For stains from food or drinks, loosen them with the same solution to prevent absorption.
- Step 5: Repeat cleaning with a clean, damp cloth to remove any residue.
- Step 6: Thoroughly dry the surfaces with a dry, soft cloth.
Common mistakes include cleaning with too much water and using abrasive cleaners that can damage the wood’s protective finish. For marks from felt-tip pens or similar stains, act promptly without rubbing longer than necessary.
When caring for Hemnes furniture in homes with children, it is important to follow the manufacturer’s guidelines: They recommend using mild cleaning agents without harsh chemicals. The material is painted solid wood, which does not tolerate moisture or mechanical stress well.
For sustainable cleaning, please use:
- No brushes or scrubbing tools
- No aggressive or abrasive cleaning agents
- Regular wiping with a damp microfiber cloth
If stains are particularly stubborn, there are professional wood care products specifically recommended for painted wood. These can also refresh the protective layer, making it easier to remove dirt in the future. When dealing with children, it is also advisable to remove stains quickly before they dry.
