ᐅ How can I prevent warping in heavily loaded Ikea Pax wardrobes?
Created on: 30 Mar 2021 08:37
ParemericP
Paremeric30 Mar 2021 08:37Hello everyone, I have a specific question: How can I prevent warping in a heavily loaded Ikea Pax wardrobe? I’m using the Pax in the size 100x236 cm (39x93 inches) with additional shelves and drawers. My main concern is that the side panels or the back panel might bend or warp under the weight. Are there any proven methods or extra reinforcements to keep the structure stable? Advice on proper loading or recommendations for reinforcing the materials would be very helpful. Thanks in advance!
Basically, the Ikea Pax is not designed to support very high loads structurally, as the side panels are made of medium-density fiberboard. To effectively prevent deformation, I recommend:
- Reinforcing the back panel with additional metal braces or a second back panel
- Using extra shelves to distribute the load
- Distributing loads as evenly as possible rather than concentrating them in a few spots
- Avoiding putting too much weight on the wardrobe doors during loading to minimize leverage effects
According to Ikea, the load limit for the Pax is about 20-25 kg (44-55 lbs) per shelf. For heavier loads, professional reinforcement is advisable.
Joshbe schrieb:
According to Ikea, the load limit of the Pax is about 20-25 kg per shelf. This information is helpful, but I wonder if Ikea’s tests also considered long-term loading? A short-term load of 25 kg is different from a permanent one that leads to material fatigue.
Furthermore, the thin back panel seems to be a weak point. The standard back panel is only about 3 mm thick (0.12 inches) and made of particleboard. Using stronger materials like plywood could significantly improve stability. Has anyone had experience replacing or reinforcing the standard back panel?
Also, it’s worth discussing whether the feet or the contact surfaces on the floor are stable enough to support the weight permanently without the structure shifting, which could lead to deformation over time.
benfa schrieb:
Does anyone have experience with replacing or reinforcing the standard back panel?Hey, I had the same problem with my Pax unit. My solution was a combination of stronger back panels (plywood, about 6 mm (1/4 inch)) and additional metal brackets inside the corners. It sounds complicated, but it was worth it – now it’s rock solid with no sagging at all.
It’s also important to distribute the load properly – so avoid placing very heavy items in the center of a single shelf, and instead spread the weight across multiple shelves.
A small tip: use gliders or floor protectors on the adjustable feet to prevent the cabinet from shifting too much when bumped or if the floor is slightly uneven. This keeps everything stable and prevents creaking.
