ᐅ How can I install IKEA Metod cabinet doors quietly?
Created on: 30 Jun 2020 09:37
KAUPAU
I recently purchased the IKEA Metod kitchen fronts and am now facing the challenge of mounting the doors as quietly as possible. Specifically, I want to avoid the usual rattling noises or loud slamming of the cabinet doors without having to buy new door soft-close mechanisms or undertake complicated modifications.
I am using the standard cup hinges from IKEA, but the damping doesn’t always seem sufficient, especially with frequent use.
I would really appreciate any tips on how to mount the Metod cabinet doors quietly—what to pay attention to during installation, possible tricks to improve the damping, or if there are alternative solutions regarding the fittings.
Thanks in advance for your support!
Nadine
1 Jul 2020 16:28
Hello KAUPAU,
I’ll try to summarize everything and suggest a structured approach. The question "How do I install IKEA Metod doors quietly?" can’t be answered with a single step, but the process roughly looks like this:
- First, check exactly which hinges are installed and whether they have the soft-close mechanism.
- If not, replacing them with IKEA soft-close hinges is often a good and inexpensive option.
- After that, correctly adjusting the hinges is crucial: check height, depth, and lateral alignment.
- Additional special dampers that can be mounted separately are an option if the existing dampers no longer work.
- Written or practical instructions from IKEA can be helpful in this process.
If you want, you can also share whether the noises come more from the door closing against the carcass or from the door sticking, as this makes troubleshooting easier.
I hope this helps you!
lofar
2 Jul 2020 07:51
the simplest and most effective way is to install the IKEA soft-close hinges and adjust the doors precisely.
Alternatively, you can also attach small felt or rubber pads to the shelf surfaces to reduce noise.
Alice
2 Jul 2020 10:04
CORYGAU schrieb:
I think it would make more sense to first check the basic installation and adjustment before replacing any parts.
I agree with that. Most noises are caused by incorrect alignment, not the dampers. Adjust first, then replace if nothing helps.
