ᐅ How can I install IKEA Metod cabinet doors for silent closing?
Created on: 13 May 2024 08:42
Z
Zeynelne50
Z
Zeynelne50
13 May 2024 08:42
I recently installed some IKEA Metod kitchen cabinet fronts and want to fix the doors so that they close as quietly as possible. Currently, the doors close quite loudly, which is especially bothersome in the evening. My specific question is how to best adjust and secure the Metod doors to achieve a soft, quiet closing. Are there particular hinge settings or accessories that should definitely be used? I’m also interested to know if different door materials (such as glass versus wood fronts) affect the closing noise. I would appreciate any detailed explanations, ideally with advice on specific screw adjustments and possibly recommended additional soft-close dampers or similar solutions.
Nathanaelk
13 May 2024 09:27
Hello Zeynelne50, your question is very clearly formulated – this avoids misunderstandings and allows me to respond more precisely. For IKEA Metod doors, the included hinges usually already have soft-close features if they are properly adjusted. Here is my suggestion on how you should proceed:
- First, check if the damping unit on the hinge is actually present. This is usually a small plastic part, a few millimeters thick, that cushions the impact.
- Adjust the hinges using the three adjustment screws: one controls the height position, one controls the lateral alignment, and the third regulates the closing force (central position, how far the door swings when closing).
- Especially with Metod, the screw located furthest inside the hinge can change the closing force. If the door is pressed too firmly against the cabinet frame, it will often close loudly.
Regarding the material: glass fronts usually have different hinges (soft-close variants) that tend to close more quietly. Solid wood doors are heavier and therefore produce more impact energy. In this case, the use of additional rubber dampers or self-adhesive door buffers on the door frame is recommended.
Have you already checked whether the supplied dampers are functional, or what type of material you are working with? I would also be interested to know whether the noises occur more when the door slams shut or when it closes slowly – this can indicate incorrectly adjusted hinges.
lyndon
13 May 2024 11:03
It is important to adjust the hinges properly to ensure the damping works effectively. Additional aids, such as self-adhesive damping pads on the inside of the door, can further reduce noise, especially with heavy doors.
I also recommend testing the doors several times after installation and gradually tightening the screws until the desired closing sound is achieved. Be careful not to overtighten, as this could bend the hinges.
Gloriagl10
13 May 2024 12:14
Adjust the hinges so that the door does not slam completely against the cabinet when closing. If the damper is broken, it is best to get a replacement. Silicone buffers on the frame also help.
GiRoyce
13 May 2024 14:45
Hello everyone! Adding to what has been said before: With my IKEA Metod doors, it has proven effective to carefully adjust the soft-close function. If your Metod hinges do not yet have soft-close units, it’s worth retrofitting them.
Here are the key points:
- Adjust the hinge screws so the door is “in position” and the soft-close damping is not blocked.
- Sometimes attaching a small spacer to the frame helps the door close gently.
With wooden fronts, closing is usually louder because the material sounds harder than, for example, glass. In practice, a small damper on the frame helps here.
Are you experiencing problems with door alignment? This can cause loud slamming due to warping.
Blavin
14 May 2024 07:53
In summary:
- Metod hinges feature integrated damping units, whose function must not be impaired by dirt or damage.
- Adjusting the three screws on the hinge is essential: height, lateral alignment, and closing force.
- The closing behavior also depends on the door construction. Glass fronts usually have softer dampers.
- Additional damping pads reduce mechanical noise on hard materials.
If there is an unpleasant noise, it is very likely that the door adjustment is not optimal or the damping is damaged. Therefore, a systematic approach to adjustment is essential.
