ᐅ How can I install IKEA Metod cabinet doors for silent closing?
Created on: 13 May 2024 08:42
Z
Zeynelne50
I recently installed some IKEA Metod kitchen cabinet fronts and want to fix the doors so that they close as quietly as possible. Currently, the doors close quite loudly, which is especially bothersome in the evening. My specific question is how to best adjust and secure the Metod doors to achieve a soft, quiet closing. Are there particular hinge settings or accessories that should definitely be used? I’m also interested to know if different door materials (such as glass versus wood fronts) affect the closing noise. I would appreciate any detailed explanations, ideally with advice on specific screw adjustments and possibly recommended additional soft-close dampers or similar solutions.
Jensson
14 May 2024 10:28
A small tutorial for adjusting IKEA Metod doors to achieve silent closing:
1. Check the screws and, if necessary, loosen them slightly to allow for movement.
2. Align the door so that it sits evenly on the frame.
3. Inspect the soft-close dampers and replace them if damaged.
4. Fine adjustment: Use the side screw to adjust the door angle so that it runs exactly parallel to the cabinet body.
5. Check the height adjustment to ensure vertical alignment.
6. Then slowly adjust the tension screw for the closing force to optimize resistance.
Multiple test closures are recommended, making minor corrective adjustments if needed.
Common mistakes:
- Screws tightened too much prevent the dampers from sliding in properly.
- Not aligning the doors evenly with consistent gaps to the cabinet body.
Are you using the IKEA soft-close hinges or the standard version?
Nathanaelk
15 May 2024 16:40
Zeynelne50 schrieb:
My question specifically concerns how to optimally adjust and fix the Metod doors to achieve a damped, quiet closing.
Based on this, I would recommend adjusting the three screws exactly according to the instructions. The key points are:
- Ideally, use a small screwdriver that fits the screws well to avoid over-tightening.
- Adjust the height first, then the lateral position, and finally the closing force.
Jensson schrieb:
Then slowly adjust the screw for the closing force to optimize the resistance.
This is very important because too much force will wear out the damping faster.
If you are already using damping buffers, check whether they are too wide, as this can push the door away too much. Another helpful tip is to tighten the doors firmly if possible and regularly check whether screws have loosened due to use—this can also cause rattling noises.
How do you see it so far—are your hinges equipped with soft-close mechanisms or are they standard versions?
lyndon
16 May 2024 09:12
In addition to the discussion: If your main goal is to make the door closing almost silent, you might also consider magnetic door dampers. They work independently of the hinges and reduce the momentum of the door. This provides further noise reduction, especially if soft-close hinges are not installed or do not meet expectations.
Of course, this is an additional investment beyond proper adjustment and is mainly aimed at users who prioritize this quiet-closing feature.
