ᐅ How can I install IKEA Metod cabinet doors for a durable and quiet performance?
Created on: 3 Apr 2020 08:37
klobi54
klobi54
3 Apr 2020 08:37
I am currently facing the challenge of mounting the doors of my IKEA Metod kitchen in a way that ensures they are not only durable but also as quiet as possible. Especially with soft-close hinges, there can sometimes be issues like rattling or loose fittings over time.
I’m interested in:
- Which screws or fastening methods have proven reliable?
- Are there additional dampers or tricks to make the closing noticeably quieter?
- How can I prevent the doors from hanging unevenly or the hinges from loosening after extended use?
I am using the original IKEA hinges but am open to improvements as long as the door remains stable and can be properly adjusted.
Looking forward to your experiences and tips for long-lasting and quiet use of the Metod doors. Thanks in advance!
raelto
3 Apr 2020 09:12
For a durable and quiet installation of IKEA Metod doors, I recommend the following approach:
- Use original IKEA screws and hinges, as these are precisely matched to the doors and cabinets.
- When attaching the hinges, ensure the mounting holes are correctly aligned and the screws are tightened firmly but not over-tightened.
- If needed, use damping elements from IKEA’s accessory range or similar silicone bumpers to prevent noisy impacts.
- Regularly check the screws to ensure they remain tight, as wood can settle slightly with use and load.
- Adjustment screws on the hinge help to align the door perfectly and eliminate any play for optimal fitting.
The combination of original fastening materials and occasional maintenance is essential for long-lasting and quiet operation.
TANBLA
3 Apr 2020 11:46
Adjust soft-close hinges properly, tighten screws firmly by hand, and use silicone dampers – this reduces noise and increases durability.
Guyju
3 Apr 2020 15:08
Here is a simple step-by-step guide for attaching IKEA Metod doors that will last long and close quietly:
1. Preparation: First, check the hinges for any damage and ideally use only original parts.
2. Mounting the hinges to the cabinet: Tighten the screws slowly and without applying too much force to avoid damaging the material.
3. Attaching the doors: Use the adjustment screws on the hinges to precisely align the door vertically, horizontally, and in depth.
4. Noise reduction: Attach damping pads (often made of soft plastic or silicone) on the contact areas between the door and the cabinet.
5. Inspection and readjustment: After a few days of use, check the screws and tighten them if needed, and realign the doors.
Common mistakes I often see are overtightening the screws and missing damping elements, which frequently cause rattling noises.
To be on the safe side, you can also choose hinge types with built-in damping, if that is available for your model.
I hope this helps!
raelto
4 Apr 2020 07:59
Guyju schrieb:
Typical mistakes I often see are overtightening screws and missing damping elements, which frequently cause rattling noises.
I agree, especially with wood-based materials like particle boards, applying too much pressure can cause cracks or material failure. A moderate tightening torque is ideal in these cases.
To add: there are also special plastic sleeves for the drill holes that make screwing more secure and protect the material from damage. These are included in some fastening kits and are valuable for durability.
Davidleo
4 Apr 2020 10:22
Super helpful contributions so far! Thanks to everyone.
I want to add that I also applied felt or foam rubber strips to the contact points in my kitchen. This not only reduces noise but also protects against minor scratches and extends the lifespan of the surface.
Rattling doors can be really annoying, but with some patience and the right materials, you can easily get them under control! Keep it up!
