ᐅ How can I secure an Ikea Pax wardrobe in a rental property without drilling?
Created on: 15 Sep 2016 10:17
ENRIKFLO
ENRIKFLO
15 Sep 2016 10:17
Hello everyone, I plan to buy an Ikea Pax wardrobe, but I’m facing a common issue in my rental apartment: drilling is basically not allowed. Therefore, I’m looking for a practical way to secure the Pax firmly and safely without damaging the walls or making holes. It’s important to me that the wardrobe is stable and won’t tip over, especially since I have children at home. Does anyone have experience or tips on how to fix the Ikea Pax in a rental without drilling into the walls or the floor? Are there alternative methods, safety devices, or special products you would recommend for this? I look forward to your ideas and suggestions!
MUMEO
15 Sep 2016 11:02
Hello ENRIKFLO,
In rental apartments where drilling is not allowed, I strongly recommend focusing on tipping prevention even without fixed wall attachments. A good and commonly used alternative is so-called edge protection strips or non-slip rubber mats under the feet of the wardrobe. These prevent slipping on smooth floors.
In addition, you can try securing the cabinet to the ceiling – if drilling there is allowed or feasible – using removable tension straps attached to pipes or ceiling moldings. If this is also not an option, furniture-specific fold-down safety devices or special anti-tip sets are recommended. These work with spring mechanisms or tension systems to keep the cabinet stable.
In summary: Without drilling, you just have to use other fixation methods that are also easy to remove. Safety against tipping with these precautions is crucial.
WARREN
15 Sep 2016 11:18
Use non-slip rubber pads under the Pax wardrobe and, if necessary, a safety kit with tension straps that can be secured to the ceiling or furniture. This way, you avoid making holes and ensure the cabinet stands firmly.
ronAlberto
15 Sep 2016 12:47
ENRIKFLO schrieb:
Are there alternative fastening methods, safety devices, or special products recommended for this purpose?
This is a fundamental question, so I would like to explain in more detail: The classic method to secure the Ikea Pax wardrobe is using the included brackets fixed to the wall. However, without drilling, it becomes more complicated, and safety is the primary concern. It is important to properly distribute the loads and stabilize the wardrobe.
A proven alternative is the use of tension rod systems. These work similarly to telescopic poles that are clamped between ceiling and floor. An example would be ceiling-to-floor tension rods with rubber feet, which prevent the wardrobe from tipping without damaging the wall surface or floor.
Please pay attention to the following details:
- The ceiling height must be measured exactly so the tension rod fits securely.
- The ceiling and floor must be load-bearing and stable (no loose plaster or flexible wooden floorboards).
- Use non-slip pads between the rubber feet of the tension rod and the ceiling/floor to prevent damage.
If the ceiling and floor are not suitable, you can experiment with special clamping strips or self-adhesive furniture stabilizers, but keep in mind these only help with slight tipping. For families with children, these solutions are often not secure enough.
Unlike expansion anchors, such systems are reversible and renter-friendly, but they require a bit more effort for installation. Your situation with children makes safety all the more important.
leteo
15 Sep 2016 17:09
ronAlberto schrieb:
A proven alternative are so-called tension lock systems that use tension rods.
Exactly, I’ve used something like that before. These things are really great because you just insert them, and they hold firmly. I used it in my girlfriend’s apartment – no holes, no hassle with the landlord!
Also, I recommend emptying the cabinet completely beforehand so you can adjust it properly before installing the tension rods. Taking a bit of extra time will definitely make it more secure in the end!
A small tip: if you can’t reach the ceiling, see if you can cleverly use baseboards – sometimes there are clamping systems that can grip onto them.
FAZAR
16 Sep 2016 08:53
Hello ENRIKFLO,
to securely fix the Ikea Pax in a rental property without drilling, I would recommend a multi-layered approach:
- First, be sure to carefully study Ikea’s instructions to understand the recommended safety precautions.
- Use non-slip mats under the feet of the wardrobe to prevent it from sliding on smooth floors.
- Installing telescopic poles (tension rods) between floor and ceiling provides a reliable stabilization without leaving holes. Some models come with rubber tips that also protect delicate surfaces.
- If tension rods are not allowed, you might consider building a sturdy frame or enclosure around the wardrobe to fix it in place, although this is more elaborate.
- Alternatively, clamp brackets that hold by pressure and attach to furniture edges can be used—suitable for light fixings.
Always keep in mind that the wardrobe must be secured against tipping, especially if heavily loaded or if children are nearby. Are you planning to fill the wardrobe with heavy items, or are there children around? That would increase the safety requirements.
I would also like to know whether the room has high ceilings and what type of flooring you have, as that affects the options for tension systems.
