ᐅ How do I assemble IKEA Metod cabinets with built-in electrical appliances?
Created on: 19 Aug 2020 09:23
Suruken
I am currently planning the installation of my new IKEA Metod kitchen, which will include built-in appliances such as an oven, dishwasher, and cooktop. However, I am unsure about the correct procedure for assembling the cabinets when these appliances are already integrated or prepared for installation.
Specifically, I am interested in the following points:
- Are there any special steps or precautions to consider when assembling Metod cabinets with built-in appliances?
- How can I ensure that the electronics and connections of the appliances are not damaged during installation?
- What should I keep in mind when installing appliances that are fitted during the assembly, compared to a typical cabinet installation without appliances?
I would really appreciate tips and experiences that can help me proceed as efficiently and safely as possible, without having to make many adjustments later on.
Thank you in advance!
Suruken schrieb:
Does anyone know if built-in cabinets with electrical appliances need to be adjusted differently (for example, in height or depth) because of cables or connections getting in the way? Are there standard dimensions that must be strictly followed?Adding to toril’s comment: The height of most Metod base cabinets is 80cm (31.5 inches) without the countertop, plus about 4-5cm (1.5-2 inches) for adjustable feet. This corresponds with most standard built-in appliances like ovens or dishwashers.
Standard kitchen dimensions:
- Depth of base cabinets: approx. 60cm (24 inches) plus countertop
- Variable front widths depending on the cabinet (e.g. 60cm (24 inches), 40cm (16 inches))
Wiring should be routed so it is not trapped in the adjustment area. The feet must remain freely adjustable to allow precise height setting.
My best-practice tip: Complete the connection installation before fitting the appliance, and check that there is enough space without pressure. Only then perform the final securing.
This approach helps avoid complaints or complicated rework later on.
