Benediktus12 Oct 2021 19:43Hello everyone,
I recently ordered an IKEA Metod kitchen with several cabinets featuring glass fronts and am now facing the challenge of assembling them correctly. My main question concerns the specific installation of the glass fronts on the Metod cabinets: Are there any particular details I should be aware of when attaching the glass doors, especially regarding the hinges and alignment? It would also be helpful to know if there are any installation tips that make aligning the glass fronts easier, so they do not hang crooked or become misaligned during use. Additionally, advice on secure fastening would be very valuable, considering that glass fronts are more delicate than regular doors.
I am already familiar with the IKEA Metod system and the usual assembly steps for the base supports and carcass, but this final step with the glass fronts is still unclear to me. Therefore, I’m interested not only in the individual installation process but also in practical experiences or common pitfalls to avoid.
I look forward to any tips, instructions, or advice you can share on this topic!
SauDietmar13 Oct 2021 08:57Hello Benediktus,
regarding your question about assembling the IKEA Metod cabinets with glass fronts, I’d like to provide a brief, structured guide that I have often recommended:
- First, assemble the cabinet carcass as described in the instructions. Make sure to use the correct holes for the hinges on the carcass.
- The glass fronts almost always have reinforced frames, so the glass is well protected. Still, be careful when attaching the hinges to avoid any damage.
- When attaching the hinges to the door, loosen all screws first. This allows you to adjust the door later.
- Then hang the door on the carcass and check if it sits evenly.
- For adjustment, the hinges usually have screws for:
- vertical alignment (raising or lowering the door)
- horizontal alignment (left/right)
- depth (to ensure the door sits flush with the carcass)
- Take your time to adjust each screw slightly and repeatedly check the door’s fit.
- Once everything fits properly, tighten the screws securely.
- Finally, I recommend carefully opening and closing the door several times to check the smoothness of operation.
A small tip: work in daylight and place the glass door on a soft surface when handling it to prevent any damage.
The glass front itself is attached via the hinges; there are no additional fasteners like clamping profile screws, as everything is secured through the door frame.
Don’t be discouraged—a good fine adjustment is normal with IKEA Metod cabinets, especially with glass fronts, which stand out more if not perfectly aligned.
If you have any more questions or encounter issues, feel free to ask!
SauDietmar schrieb:
When attaching the hinges to the door, you should first leave all screws slightly loose.This is a very important tip that I want to emphasize here: Having flexibility when adjusting the screws is crucial for properly aligning the glass front. A common mistake is tightening the screws fully right away, which makes precise adjustment much more difficult. Additionally, you should take advantage of the slight play in the hinges, which is especially necessary with glass fronts due to their more delicate nature.
Another point: If the frame of the glass front is not exactly square, do not try to force the adjustment. Instead, first check that the cabinet itself is properly positioned. Sometimes the issue lies with the base rather than the door.
In summary, I recommend:
- Only lightly tighten the screws on the hinges when hanging the door
- Perform multiple readjustments before fully tightening
- Check that the cabinet is level before installing the doors
Following this approach helps avoid many problems when aligning the glass front.
Benediktus schrieb:
I’m not only interested in the individual assembly step but also in practical experiences or common pitfalls that should definitely be avoided.I can only confirm that. Based on my own experience, here are some additional points about the glass fronts with Metod:
- The glass doors are considerably heavier than regular doors, so you should definitely have an extra pair of hands when hanging them, if possible.
- Even though the frame is sturdy, excessive force during adjustments can cause stress on the glass.
- When attaching handles or knobs, make sure to use the holes on both sides correctly, as positioning is more critical with glass fronts.
- When adjusting the door, try to use a spirit level to detect and intentionally correct any slight misalignments.
From my assembly experience, the thickness of the frame and the door’s weight require more precise fine-tuning. One other small detail: IKEA often supplies hinges with a depth adjustment screw, which should definitely be used with glass fronts to avoid damage to the glass surface when closing the door.
Last but not least: Using the supplied wooden wedges or spacers can be very helpful when hanging the door to fix it perfectly in position until all screws are fully tightened.
Good luck with your assembly!
