ᐅ How can I install IKEA Metod cabinets space-efficiently in small kitchens?
Created on: 17 Nov 2024 08:34
tauga
I have decided to design my small kitchen using IKEA Metod cabinets. The problem is that the available space is very limited, both in width and depth. My specific question is: How can I install IKEA Metod cabinets in a space-saving way in small kitchens without sacrificing storage and functionality? Are there particular combinations, dimensions, or installation methods that work especially well? What tips do you have for making the most of the available space, for example regarding corner solutions, cabinet height, or the usability of the inside of doors?
I look forward to your experiences and recommendations!
To make the most of your ceiling height of 2.40 m (7 feet 10 inches), I recommend combining tall base cabinets (about 90 cm (35 inches)) with a countertop, complemented by wall cabinets of 60 or 80 cm (24 or 31 inches) in height. The depth of the wall cabinets can be reduced to 30–35 cm (12–14 inches) to visually open up the space.
It is important to maintain the distance between the countertop and the wall cabinets—ideally around 50 cm (20 inches). This ensures enough work surface while preventing the cabinets from feeling bulky.
Consider keeping the base cabinets in a consistent depth, around 60 cm (24 inches), and then offset the wall cabinets with shallower depths—this creates a better spatial effect.
Additionally, vertical organization systems and pull-out interior compartments in the cabinets improve visibility and save space.
Also important: fully account for the door swinging inward. If possible, use a sliding door or door soft-close mechanism to avoid reducing the movement space.
tauga schrieb:
Should the upper cabinets be less deep to avoid the kitchen feeling cramped?That is exactly the right approach. Visual lightness is important in rooms with lower ceiling heights, so wall cabinets with a depth of 30–40 cm (12–16 inches) or open shelving systems are better suited for the upper area. Although storage space decreases slightly with reduced depth, the room feels significantly larger and more open.
Choosing lighter colors for the cabinets also contributes to a greater sense of spaciousness in a small kitchen.
