ᐅ How can I install IKEA Metod cabinets space-efficiently in small kitchens?
Created on: 17 Nov 2024 08:34
tauga
tauga
17 Nov 2024 08:34
I have decided to design my small kitchen using IKEA Metod cabinets. The problem is that the available space is very limited, both in width and depth. My specific question is: How can I install IKEA Metod cabinets in a space-saving way in small kitchens without sacrificing storage and functionality? Are there particular combinations, dimensions, or installation methods that work especially well? What tips do you have for making the most of the available space, for example regarding corner solutions, cabinet height, or the usability of the inside of doors?
I look forward to your experiences and recommendations!
Elijah42
17 Nov 2024 09:12
I would recommend choosing tall cabinets whenever possible to make the most of vertical space. Corner cabinets with a carousel are space-efficient and provide plenty of storage. The basic guideline is to opt for narrower base cabinets if the width is limited and to install wall cabinets as high as possible.
dijan
17 Nov 2024 10:45
The Metod series is a real all-rounder when you get a bit creative! 😄 For example, I find corner cabinets with pull-outs brilliant, as they create double-usable space without having to bend down. Mixing wall and base cabinets at different heights also turns a small kitchen quickly into a versatile workspace. The key is flexibility! Make sure to match your measurements precisely—there are many sizes available. And think of it as a puzzle—the space needs to be put together well to save room effectively.
KAULIS
17 Nov 2024 14:03
Please consider the following: The standard depth of Metod base cabinets is usually 60 cm (24 inches), which is often too deep for small kitchens. Here, 37 cm (15 inches) deep frames combined with pull-out interiors are a good option to maximize storage space. For wall and hanging cabinets, it is advisable to use the maximum height of 80 cm (31 inches) or 92 cm (36 inches), as this significantly increases vertical storage capacity. The use of corner solutions like the 'Magic Corner' or LeMans pull-outs is recommended. Planning cabinets in widths of 20 cm (8 inches), 30 cm (12 inches), and 40 cm (16 inches) also allows flexible adaptation to niches. Furthermore, I recommend replacing doors with sliding or folding doors when the space between the kitchen unit and opposing furniture is limited.
Palenar
18 Nov 2024 07:51
I would first need more details about your kitchen space and usage habits, but in general, I can recommend the following detailed approach:
- Measure the room: height, width, depth, and any obstructions (radiators, plumbing, electrical outlets)
- Choose narrow base cabinets (at least 20 cm wide (8 inches)) for countertop space in peripheral areas
- Use tall wall cabinets with adjustable shelves to store items stacked vertically
- Corner cabinets with carousel or swing-out mechanisms are very practical; other corner solutions often provide additional space
- Consider whether to use cabinet fronts with integrated handles or push-to-open features to save handle width
- Utilize the inside of cabinet doors with hooks or bottle holders
- Installing shelves above the cabinets often makes sense and helps utilize edge areas
Can you specify your ceiling height and whether water/drainage or electrical connections are already fixed in position?
tauga
18 Nov 2024 10:22
Palenar schrieb:
I would first need more details about your kitchen space and usage habits, but in general I can recommend the following detailed approach:
Thank you for the detailed initial input! My ceiling height is 2.40 m (7 ft 10 in), the water connection is fixed in the corner, as is the drain. Electrical connections are flexible. The kitchen width is 2.10 m (6 ft 11 in), depth about 2.40 m (7 ft 10 in), so it’s quite compact. I want to have the most space for cooking utensils, pots, and dishes. Shelves above the cabinets sound interesting; I hadn’t thought about that before. The kitchen door opens inward, so the space remains tight.
Do you have tips regarding cabinet height and combining tall and lower cabinets, especially considering the low ceiling height? Would it be better to keep upper cabinets less deep to avoid the kitchen feeling cramped?
