ᐅ How can I securely assemble Ikea Hemnes furniture on uneven floors?
Created on: 14 Oct 2023 10:17
lopuson
lopuson
14 Oct 2023 10:17
I am facing the challenge of assembling my Ikea Hemnes furniture on a slightly uneven wooden floor. The furniture is generally stable, but due to the uneven surface, it sometimes wobbles or does not stand perfectly straight, which probably isn’t good for the structure in the long run.
My question is: How can Ikea Hemnes furniture be assembled so that it remains stable on uneven floors without wobbling and maintains solid stability over time? Are there specific techniques, screws, additional reinforcements, or leveling materials you would recommend? I want to avoid damage or instability caused by small irregularities under the legs.
Looking forward to your tips and experiences!
Gloriagl10
14 Oct 2023 11:03
I would recommend attaching small furniture glides or felt pads directly under the feet. This often compensates for minor unevenness. If the surface is more uneven, plastic shims or thin wood pieces can also be used as a base underneath.
Domau0
14 Oct 2023 15:27
In such cases, it is sensible to approach the setup systematically. First, you should accurately measure the floor’s surface area or at least mark the highest and lowest points.
- Slightly lift the furniture and use small, stable shims made of plastic or wood to level the feet at specific points.
- Make sure that all screw connections of the Hemnes furniture are consistently and properly tightened to avoid unnecessary wobbling.
- Some users report that a substructure made of angle profiles or an additional wall stop can stabilize the furniture, especially for tall cabinets.
- Additionally, self-adhesive rubber pads can be attached under the feet; these increase friction and prevent shifting.
Have you already tried to precisely locate the floor unevenness to compensate for it accordingly?
lopuson
15 Oct 2023 09:42
Domau0 schrieb:
Have you already tried to precisely locate the floor unevenness to be able to level it selectively?
Thank you for the detailed tips. So far, I have only done a superficial check: there are some small bumps, for example one spot where the floorboards are slightly higher, and another spot where the parquet has slightly sunk. I haven’t taken exact measurements yet, as I first wanted to ask if there are any specific solutions for the Hemnes series. You mentioned angle trims or wall stops — would these be recommended for a 3-door Hemnes wardrobe standing against the wall? Or is it sufficient to add padding under the feet at certain points?
Also, I’m curious: how well does the veneer surface on the furniture legs tolerate thicker padding underneath without getting damaged?
CHENFAR
15 Oct 2023 11:58
The Hemnes furniture from Ikea is made of solid pine, which generally ensures stability; however, the legs are not adjustable, which can be problematic on uneven floors.
- Spot leveling with wooden or plastic shims is a proven method to prevent wobbling.
- To avoid damaging the surface of the furniture legs, these shims should be wrapped with felt or rubber.
- For additional stability, especially with tall cabinets, I recommend attaching a corner brace to the back panel and securing the cabinet to the wall (assembly kits for Ikea furniture usually include dowels and screws for this purpose).
- It is also important to tighten all screw connections with the appropriate torque to minimize twisting and looseness.
Additional advice from a flooring professional is only necessary if the unevenness exceeds 5 mm (0.2 inches) difference per meter (3.3 feet); otherwise, the measures mentioned above are sufficient.
