ᐅ How can I install Ikea Besta units on an uneven floor?
Created on: 9 Apr 2021 18:07
Theolu
Hello everyone, I am currently facing an issue with my new Ikea Besta shelving unit: the floor in my apartment is not completely level, which causes the Besta unit to either wobble or become slightly warped when I set it up. Despite multiple attempts to level it, it still wobbles slightly, which I attribute to the uneven floor.
My question to the community is: how can I best level the Ikea Besta on an uneven floor without compromising stability or appearance? Are there specific techniques, materials, or adjustable feet that work particularly well? I look forward to your practical tips and experiences!
Guyju
10 Apr 2021 07:13
Good morning! To stabilize and neatly level your Ikea Besta on uneven floors, I recommend the following steps: Step 1: Precisely measure the floor irregularities, for example, using a spirit level. Step 2: Choose appropriate leveling materials. For small unevenness (up to approximately 5mm (0.2 inches)), self-adhesive felt pads or plastic shims are suitable. Step 3: For larger height differences, Ikea Besta does not come with adjustable feet by default. Therefore, it makes sense to install screw-in adjustable feet from a hardware store. These can be screwed onto the existing feet and allow for millimeter-precise adjustment. Step 4: The adjustable feet must be securely installed – drilling is often necessary to fix them firmly. Step 5: To prevent wobbling and tipping, always fasten the furniture to the wall. This also helps reduce safety risks. Step 6: Finally, double-check the level before and after adjustment using the spirit level. Tip: Especially on wooden floors, specially profiled washers can help improve stability. This ensures a stable, level setup and prevents long-term damage to the furniture or floor.
Danial
10 Apr 2021 14:52
Guyju schrieb:
For larger height differences, Ikea Besta does not come with adjustable feet as standard.
That gets to the heart of the matter. However, you should also consider that fitting different feet often voids the furniture’s warranty and may even affect its structural testing. Have you compared the load capacity of the original feet with the replacements?
Marlenepa schrieb:
Please make sure to check whether you can secure the shelving unit to the wall.
This is essential. Without wall fixing, a shelving unit can easily tip over on uneven floors, posing a safety risk. This point is especially important for taller Besta units.
One more note: floor irregularities might be better addressed using a leveling compound or self-leveling screed. Although this requires more effort, it provides a long-lasting and professional solution.
mo-hau
11 Apr 2021 08:44
Danial schrieb:
The unevenness in the floor might be better addressed with a leveling compound or self-leveling screed.
That is correct. Especially when the unevenness exceeds 5-7 mm (0.2-0.3 inches), a floor leveling solution is optimal, also to avoid long-term issues with equipment or furniture. The effort can be worthwhile if multiple pieces of furniture are affected or if the floor has not only small dents but also larger depressions.
Regarding the installation of the feet: After removing the standard foot mounts of the Besta unit, it should be ensured that the new foot brackets are compatible and that the load is evenly distributed. If in doubt, it is essential to seek a stability-related recommendation.
Theolu
12 Apr 2021 10:27
Thank you all for the helpful advice! I will get a spirit level to take measurements and record the differences at the base points. Your tips about the adjustable feet and placing felt pads underneath sound very promising. I also appreciate your suggestions regarding wall mounting. Some of the floor irregularities are quite significant, so I am also considering whether a screed leveling might be a more sustainable solution in the long run. I will try some minor fixes first and then decide if I need to address the floor. If I find a suitable solution, I will get back to you with feedback.
