I am planning to purchase the Ikea Brimnes bedroom series and have started looking into the assembly process. Since I prefer not to waste time on frustrating assembly sessions, I am specifically interested in how challenging the assembly of Brimnes actually is.
What is important for me to know:
- How detailed and easy to understand are the included instructions?
- Do you need special tools or particular skills?
- Are there any common problem areas or issues that often come up?
- How much time should one realistically allow for assembly when working with two people?
I look forward to your experiences and assessments, preferably with tips that are also helpful for someone with only moderate DIY skills. Thanks in advance!
Hello Dorula,
Regarding your question about how challenging the assembly of the Ikea Brimnes is, I can say from personal experience that it is definitely doable for average DIY enthusiasts. The instructions are fairly well organized, but the many individual parts can feel a bit overwhelming at first.
You mainly need a screwdriver and a hammer, which often are not included, so it’s best to have them ready. Some screws require a bit of patience, especially when putting together the larger components like drawers or the headboard frame.
My advice: work with two people, as handling the parts alone can quickly become impractical. Assembling my 2.00 m (6 ft 7 in) wide bed with drawers took me about 3 hours. If you have little experience, it might take a bit longer—but it’s definitely manageable.
If you’re unsure at certain points, it helps to carefully review each step before assembling to avoid mistakes that could cost time later. I hope this is helpful!
Regarding the question of how challenging the assembly of the Ikea Brimnes series is, I would like to clarify the following:
- The assembly instructions are standardized and logically structured, but, as is typical with Ikea, they rely mostly on pictograms, which can make interpretation difficult for beginners.
- No special tools are required; common household tools, especially a Phillips screwdriver or a cordless drill, are recommended.
- Critical points: Proper alignment of the drawer slides and careful installation of the back panels require attention to detail; otherwise, the furniture may not close properly.
- Time required: For a single piece of furniture like the 3-door wardrobe model with drawers, budget around 3 to 4 hours, assuming two people work together.
Recommendation: Planning the assembly area is important — flat, clean surfaces protect the parts and make handling easier.
Hello Dorula, I would like to provide a more detailed overview of assembling the Ikea Brimnes, as I place particular importance on precise information.
First: Tools – as mentioned before, a standard Phillips screwdriver and a hammer are sufficient. A cordless drill can speed up the process but is not absolutely necessary. Be careful not to apply excessive force when driving the screws, as the material is particleboard and too much pressure can cause the surface to chip or tear.
Second: The individual steps.
- Work steadily but carefully: the instructions guide you through the assembly in small sequences, but some screw positions may require precise alignment. It is worth adjusting parts before fastening.
- Pay special attention to the drawer runners: improper adjustment can cause them to stick or not function smoothly.
- The back panels are fixed with small nails; be cautious here to avoid splitting the material.
Third: Time and organization.
- Allow at least 3 to 5 hours, depending on your experience or whether you have assistance.
- Sort all screws and parts before assembly to avoid confusion.
I’m curious: how much experience do you have with assembling similar furniture, so I can offer more specific tips if needed?
Palenar schrieb:
I’d be interested to know: How much experience do you have so far with assembling similar furniture, in case I can give you more specific advice?Thank you for the detailed information! So far, I have assembled several smaller IKEA wardrobe models, shelves, and dressers, mostly without major issues. However, it often took me several hours to complete a larger piece of furniture.
I consider myself someone who works in a fairly systematic way but is not very skilled with specialized tools or specific craftsmanship techniques. Still, I definitely have a good sense for precise work.
If you think this is a sufficient foundation, I would be interested in concrete points where extra caution is required, also to avoid mistakes and later corrections.
Dorula schrieb:
I consider myself someone who works systematically but is not very experienced with special tools or specific craft techniques.Then I would give you the following specific advice:
- When assembling the side panels: Make sure to align the pre-drilled holes for dowels and screws precisely to avoid unnecessary force and material deformation.
- Drawer installation: After inserting the drawers, check that the drawer slides fit snugly and move smoothly. This is often the most critical point, as otherwise the drawers will not glide easily in the end.
- Back panel: When nailing the thin back panels, use a small hammer and only tap the nails lightly to prevent splitting.
As for tools, as mentioned, a Phillips screwdriver, a small hammer, and if possible, an Allen key from the set (usually included with flat-pack furniture) are sufficient.
If you keep these points in mind, you will avoid mistakes that would otherwise cost you more time.
