Good morning everyone, I have some Hemnes wardrobe doors from Ikea that have shifted alignment over time. Specifically, the doors no longer close properly and hang slightly crooked in some cases. Therefore, my question to the community is: How can you readjust the wardrobe doors on an Ikea Hemnes wardrobe to make them close straight and flush again? Are there specific steps or tools that should be used for this? I have heard that some hinges have adjustment screws, but I am not sure how to adjust them correctly without damaging the doors. I would appreciate any tips or detailed instructions.
Hello, Ikea Hemnes cabinet doors usually have concealed hinges that can be adjusted at several points. The following steps are important: - First, slightly loosen the door by checking the fastening screws on the hinge, but do not remove them completely. - There are generally three adjustment options: horizontal, vertical, and depth (distance to the cabinet front). - For horizontal and vertical adjustments, there are usually screws directly on the hinge that can be adjusted with a Phillips screwdriver. - The depth is often adjusted via a separate screw. - Proceed step by step, turning only a little at a time and closing the door in between to check the fit. - Warning: Over-tightening can damage the hinge or warp the door. - A small tool like a spirit level can help if you want precise alignment.
Gino38 schrieb:
Work step by step, turning just a little each time and closing the door in between to check the fit.Exactly, that’s really the key! I always say, "Better safe than making adjustments later." 😄
Sometimes you can feel that even a small quarter turn on the hinge screw makes a huge difference. Also, if you tighten the screws a bit more securely, the doors won’t slip out of place so easily again. Enjoy the screwing—it’s almost fun once you get the hang of it!
JEREMIAH381 Feb 2023 07:51I understand the frustration when cabinet doors don’t close properly. In my case, the door also started to hang slightly crooked after a while. I tried the tips shared here and had good results by patiently and carefully adjusting each screw step by step. If you’re unsure about this, I would recommend taking your time and possibly working with a partner to better stabilize the door while making adjustments. This way, you can avoid damage and unnecessary frustration.
Adisleo schrieb:
I have heard that some hinges have adjustment screws, but I am not sure how to adjust them correctly without damaging the doors.It is absolutely correct that Ikea Hemnes hinges have adjustment screws. The most important rule is to turn the screws slowly and in small increments. If you get stuck, simply stop, check the new alignment, and then continue adjusting. Using a Phillips screwdriver is perfectly fine; the key is not to apply too much force. If the door no longer closes properly after adjustment, you can easily counter-adjust.
