ᐅ How can you prevent stress cracks in Ikea Platsa wood panels?
Created on: 9 Aug 2022 18:06
Nicopau
Nicopau
9 Aug 2022 18:06
I am currently planning to assemble an Ikea Platsa cabinet and have already noticed or heard about stress cracks appearing in some of the wooden panels if they are handled incorrectly. Since the panels are quite thin and made of wood-based materials, I am wondering how to effectively prevent these stress cracks. I am especially interested in whether there are specific assembly or storage tips that can reduce the risk of stress cracks. Also: does the indoor humidity level play a role? And should certain surface treatments be applied before assembly?
Does anyone have experience or reliable advice? I would prefer to avoid returns or unnecessary effort later on.
Thanks and best regards!
FEKAU
9 Aug 2022 19:12
The formation of stress cracks in Ikea Platsa wood panels is mainly caused by fluctuations in moisture and mechanical stress. To prevent this, the material should be stored before assembly in a location with a constant humidity level, ideally between 45 and 55% relative humidity.
Additionally, I recommend:
- Ensuring even fastening during assembly to avoid localized stress.
- Avoiding long-term storage of panels lying flat without support to prevent warping.
- Avoiding environments that are too dry or too humid, as engineered wood products are particularly sensitive to extreme changes in moisture.
Surface treatment with moisture-resistant coatings is generally possible, but Ikea panels are usually coated with melamine resin, which already provides protection. The most important factor is to prevent direct exposure to moisture during use.
V
vinpau
10 Aug 2022 08:23
Great topic! Stress cracks can really spoil the fun of furniture making, but with a few tricks, you can prevent them:
- It’s helpful to store the panels for a few days in the room where they will eventually be placed. This allows them to adjust to the temperature and humidity – this makes a big difference!
- Pay attention during assembly: don’t tighten the screws too much, as this puts pressure on the panels!
- After that, make sure the rooms are not too dry or too humid. For example, I often use a humidifier in winter, which is good for the furniture.
I once had a slight crack in a panel, and since then I always keep these points in mind. Good luck with the assembly, it’s really enjoyable when everything fits together! 🙂
MUMENAR
11 Aug 2022 10:37
FEKAU schrieb:
The formation of stress cracks in Ikea Platsa wood panels is primarily due to fluctuations in moisture and mechanical stress.
That is basically true, but it is a bit too simplified. It is also important to consider the material quality and manufacturing processes. Ikea engineered wood products are often coated, which reduces moisture and oxygen exchange, but stress cracks can still occur especially at edges and cut surfaces.
Therefore, it is important to properly protect the edges, for example by sealing them afterwards or using edge protection profiles.
Proper installation of the panels is also crucial: if they are overloaded or incorrectly installed within the frame, the risk of cracks increases even with ideal indoor humidity.
I also often question whether the recommendation to maintain indoor humidity between 45–55 % is really practical. In many homes, especially in winter, the humidity is significantly lower. It would be interesting to see long-term studies on how much these conditions actually pose a risk.
Ramon4
12 Aug 2022 15:51
Hello Nicopau,
I’m happy to help clarify this topic: stress cracks in Platsa panels usually occur due to differences in moisture and temperature, as mentioned before.
It is advisable to acclimate these panels in the final room for at least 48 hours before installation. During this time, they should lie flat on a level surface, not stand upright or lean against a wall.
- Avoid moisture during storage and installation
- Use small spacers during assembly so the panels do not rest directly on smooth, damp floors
- Tighten screws and fasteners gently, as the panels cannot withstand strong tension or pressure
- If needed, use edge protection strips from Ikea or a second choice to protect the cut edges
This approach will largely prevent stress cracks. I have had the best experience using it.
Feel free to ask if you have any further questions!
