ᐅ How can you install IKEA Metod cabinet handles yourself?
Created on: 12 Aug 2020 14:37
Rodamar
Rodamar
12 Aug 2020 14:37
Hello everyone, I would like to know how to install Ikea Metod cabinet handles myself. I recently put together a kitchen and want to attach the handles to the Metod cabinet doors, but the installation doesn’t seem straightforward to me.
Specifically, I’m interested in:
- Which tools I exactly need
- How to measure and drill the holes correctly to align the handles properly
- Any tips for attaching the handles as straight and securely as possible
Maybe someone has experience with this or can provide a step-by-step guide. Thanks in advance!
lise56
12 Aug 2020 15:16
Generally, IKEA Metod doors usually come with drilling templates, which allow you to mark the holes for the handles precisely. That’s already a solid starting point.
Regarding your question about tools: typically, a cordless drill is sufficient, possibly with a drill bit of the appropriate diameter for the holes—often around 5mm (0.2 inches). Additionally, a small spirit level can be helpful if no template is available.
Your goal to install the handles as straight and stable as possible is reasonable since crooked handles can significantly affect the overall look.
However, I would critically consider how accurately the template fits—because even small misalignments are difficult to correct later without extra work.
In short: have you checked if the drilling templates are actually included with your doors? Sometimes there are different door types in the Metod system where the handle installation can vary.
Jatau
12 Aug 2020 15:43
Tools you will need: cordless drill with the appropriate drill bit (5mm / 0.2 inches). Use the included drilling template from Ikea, which ensures precise positioning. It’s best to cover the door from the back to avoid any damage.
Joe52
13 Aug 2020 10:08
Some time ago, I also installed Metod handles and understand well that it can feel uncertain at first.
What helped me:
- First, prepare and lay out all screws and handles completely
- Mark the drill points using the Ikea template, if available
- Pre-drill with a thinner drill bit to avoid splintering
- Enlarge the holes with the appropriate larger drill bit
- Then loosely attach the handles and check again if the position is correct
- Afterwards, tighten the screws, but not too much to prevent the fastenings from ripping out
I would also recommend, if possible, working with two people—one holds the door or tool steady, which makes many things easier.
If you need more detailed tips, feel free to ask.
