ᐅ How can small cracks in Malm wood be repaired?
Created on: 7 Dec 2018 10:37
meonar
meonar
7 Dec 2018 10:37
Hello everyone, I have a piece of furniture made from Malm wood that has developed some small, relatively fine cracks on the surface. Since I want to preserve the wood and repair it as inconspicuously as possible, I’m wondering what the best way is to fix small cracks in Malm wood without making the repair too visible or damaging the surface.
I was thinking about using fillers or oils but haven’t found any instructions on how to proceed with this particular type of wood. I would really appreciate tips and guidance on which materials are suitable, the exact repair process, and whether any final surface treatments (e.g., varnish or oil) are necessary to ensure the cracks remain stable in the long term.
Guyju
7 Dec 2018 11:02
Hello meonar,
Regarding your question: The best way to repair small cracks in Malm wood is as follows:
1. Preparation: First, carefully clean the cracks using a small brush or vacuum cleaner to remove any dirt.
2. Choose filler: It’s best to use a mixture of suitable wood filler or wood putty that matches the color of the Malm wood. Alternatively, you can mix wood dust waste material with some wood glue to create a flexible filler paste.
3. Application: Apply the filler with a small spatula and press it firmly into the cracks. Remove any excess immediately before the filler dries.
4. Let dry: Allow to cure for at least 12 hours, depending on the product instructions.
5. Sanding: After drying, gently sand smooth with fine sandpaper (grit 320–400).
6. Finishing: Afterwards, it is recommended to apply oil or a soft coat of varnish to seal the surface and visually blend the repair area with the rest of the wood.
It is important not to obscure the grain too much when working with Malm wood. Therefore, apply several thin layers rather than one thick layer.
Common mistakes include using too coarse filler or applying too much, which makes the repair very noticeable.
I hope this helps you for now!
jordanvin
7 Dec 2018 11:45
Guyju schrieb:
It is important that the grain of Malm wood is not too heavily covered.
This is brilliant! Thanks for the great tips, Guyju! At first, I also thought about using regular filler for my small cracks, but that would completely seal the wood and ruin the natural look! 🙂
I can only encourage meonar to approach this carefully. With patience and the right materials, you can restore small cracks to something really beautiful. The wood almost shines like new afterward! Good luck, you can do it!!
Nigel
7 Dec 2018 12:09
First, sand and clean the cracks.
Then fill them with wood putty, slightly overfilling.
After it dries, sand again and apply oil.
Done.
raelto
8 Dec 2018 08:23
As a supplement: Malm wood, due to its porous and sometimes resin-rich structure, is more prone to stress cracks.
Therefore, I recommend choosing elastic wood filler that offers some flexibility, which helps reduce cracking caused by movement.
Additionally, lightly moistening the crack edges before applying the filler improves adhesion.
A final treatment with a thin, penetrating wood oil that includes UV protection also increases the durability of the treatment.
Painting can smooth the appearance, but it increases the risk of visible transitions, especially on untreated natural wood. In my experience, oil treatment is more practical.
lochen
9 Dec 2018 17:52
raelto schrieb:
It is also recommended to lightly moisten the edges of the cracks before applying the filler
This is an important point that I would like to emphasize. Especially with Malm wood, natural drying and the resulting formation of cracks can be very sensitive.
I would also recommend briefly checking the climatic conditions before the repair – too high humidity can delay drying, while too low humidity can cause the wood to shrink more.
Regarding the material: a water-based wood filler is often more compatible than solvent-based fillers, as the latter can damage the wood. The linseed oil applied after the repair gives the wood a nice depth and also provides protection.
With a bit of patience and care, you can achieve an almost invisible result. 🙂
