ᐅ How do I repair torn edges on MALM beds?
Created on: 2 May 2022 08:37
Ilanfo
Hello everyone, I have noticed that some edges of the frame on my Malm bed have developed cracks and chipping. These look unattractive, and I am concerned that the damage might worsen over time.
I am interested in learning how to best repair these cracked edges myself, without having to disassemble the bed or order entirely new parts.
Are there specific adhesives, fillers, or treatments that work especially well on the surface of MALM beds made from particleboard or laminate?
I would appreciate any advice, material recommendations, or practical experiences you can share!
BOSULE
2 May 2022 13:37
For repairing torn edges on Malm beds, I recommend using a special plastic filler that remains flexible and does not become brittle. Traditional wood filler can sometimes chip off when used on chipboard with a laminate surface.
Before application, the surface should be thoroughly cleaned and lightly roughened to ensure better adhesion of the filler. After drying, carefully sand the area with fine-grit sandpaper.
Finally, apply a thin layer of color-matched clear lacquer or laminate care product to seal the repaired spot.
KAMERON
2 May 2022 14:11
The following procedure has proven effective for repairing cracked MALM edges:
1. Remove any large broken parts and lightly bevel the edges.
2. Clean the surface, preferably with isopropanol.
3. Use a plastic filler that is approved for laminate surfaces.
4. Smooth out the filler and allow it to fully cure.
5. Carefully sand with fine-grit sandpaper (grain 220+) to preserve the edge shape.
6. Seal the area with waterproof varnish or laminate adhesive.
The best materials can be found in well-stocked hardware stores or furniture repair kits designed specifically for laminate.
Ilanfo
2 May 2022 15:48
Thanks for your tips!
SUFOJE schrieb:
My advice would be to first clean the damaged surface thoroughly and remove any loose parts.
That sounds good – do you think it’s possible to apply the plastic filler directly onto the laminate layer, or should the surface be slightly roughened beforehand?
@KAMERON Your step-by-step instructions seem very logical, especially the tip about using isopropanol for cleaning.
Is there a specific type of plastic filler you would recommend? I often read about different types (2-component, single-component, etc.).
SUFOJE
2 May 2022 17:03
Very good question, Ilanfo!
Yes, it is indeed advisable to lightly roughen the laminate surface – for example, with very fine sandpaper (grit 320). This significantly improves the adhesion of the filler. However, you should work carefully to avoid causing further damage.
Regarding the plastic filler: a single-component (easy to use) filler is generally more practical for home use. Two-component fillers offer higher strength but require precise mixing ratios and quick application. I have personally had good experiences with products designed for laminate repairs available at hardware stores, which are specifically suitable for plastic surfaces.
chen67
2 May 2022 19:56
One small tip from me: After the putty has dried and been sanded smooth, try gently “dabbing” the edge with a slightly damp cloth. This often removes sanding scratches and makes the transition look much more natural.
Sounds strange, but it really works great! 🙂
elgla
3 May 2022 08:22
This also happened to me with my MALM bed a while ago, and I was initially a bit frustrated because you do get the feeling that furniture quickly loses its charm from such small damages.
Your input here is really helpful; I will now try fixing it myself using plastic filler. Thanks also for the encouragement – sometimes it feels like you have to hire professionals first, but with your help, it becomes easier. 🙂
