ᐅ Are spare parts available for especially old Malm models?
Created on: 27 May 2022 08:17
Nonse
Nonse
27 May 2022 08:17
I have a question regarding particularly old models of the IKEA Malm series. Specifically, I am interested in whether replacement parts are still available for the first generations of these furniture pieces. Mainly concerning fittings such as hinges, drawer slides, as well as side panels or bottom boards – so not just typical screws or pins, but original or at least compatible parts that are still obtainable even after many years.
Does anyone know if IKEA or third-party suppliers provide such replacement parts for Malm products that are significantly older than 10 years? Are there any special recommendations for sources, or is it more common nowadays to replace whole modules?
I look forward to your knowledge and tips, thanks in advance!
SAWYERR
27 May 2022 08:34
IKEA usually only sells spare parts for models from the last 5-7 years. For very old Malm wardrobes, you often have to rely on used parts or alternatives from the aftermarket.
RENMA
27 May 2022 09:05
The availability period for spare parts at IKEA is usually about 10 years after a model is discontinued. For older Malm models, it is therefore increasingly difficult to obtain original spare parts directly from IKEA.
As an alternative, specialized hardware suppliers or platforms like eBay can be recommended, where used or compatible parts are occasionally offered. Renovating or purchasing affordable universal fittings can also be a solution.
klo61
27 May 2022 10:12
I understand your situation well. Older Malm models were very popular and sturdy back then, but spare parts are often a challenge. Many users tried to improvise with universal fittings at the time.
If you can, check out local second-hand shops or furniture repair workshops. Sometimes they collect such parts. Regarding original IKEA spare parts: customer service usually only assists with products made within the last 10 years. Older pieces are generally no longer supported – meaning repairs typically require third-party or universal parts.
If it’s about drawer slides: a tip is to pay close attention to the measurements and possibly have a carpenter make suitable adapters.
KARJU
27 May 2022 11:45
For context: The Malm dresser was first introduced in the early 2000s, available in various generations with some changing components. Simple connectors were replaced more often than complex guiding elements.
A critical issue is that IKEA is actively reducing spare part availability for older furniture to minimize storage costs. As a result, specific components are disappearing from the market more quickly. If you are specifically looking for original Malm drawer slides, hinges, or side panels for older models, there is now very little stock available.
Your best option is to search targeted forums, secondhand platforms, or consider repairs using suitable universal parts, which are often highly adaptable.
Taubi
27 May 2022 13:10
If it’s just about a broken drawer slide or a damaged hinge, simply buy universal replacement parts. Original parts are hardly available anymore for old Malm models. Properly removing and modifying these components is often easier than trying to find original parts.
