Hello everyone, I am currently considering how to best use the Ikea Platsa system as a room divider in a small open-plan apartment. My apartment is about 35 sqm (375 sq ft), and I want to cleverly separate areas like living, dining, and sleeping with a room divider without making the space feel cramped. I imagine that Platsa could serve as storage on one hand, while also allowing enough openness for light to pass through so it doesn’t feel like sitting in a closed-off box. Does anyone have experience using Platsa as a room divider? How did you choose, combine, or possibly customize the modules? I am especially interested in the best approach regarding stability and appearance. Thanks in advance!
Hi! Using the Platsa as a room divider is a really smart idea – practical and stylish at the same time 😄. I did the same in my home: I chose a mix of open and closed modules. This keeps the space airy while still allowing for plenty of storage. My recommendation is to pay attention to the back panels – leaving them open gives the look of a shelving unit, while adding them creates a solid wall. Also, I stacked some modules on top of each other and secured them to the wall for extra stability, so everything is very sturdy. And a little tip: you can combine some modules with doors to avoid a cluttered appearance. All in all – a real all-rounder!
I also find the topic of room dividers with Platsa interesting, since I have often faced the challenge of separating the living room and workspace in a small apartment. The mix of open and closed modules allows not only for visual privacy but also discreet storage of personal items. I just wanted to mention that with a fixed partition like this, it’s important to consider how you balance openness and privacy. For me personally, it was important that light reaches everywhere, but that I also have some quiet time. If you have similar needs, here’s my tip: you can install Platsa in rows with transparent or open sections — this way, the space feels divided but not closed off.
Hello, I would like to provide a more structured guide on how to optimally use Ikea Platsa as a room divider. It is worthwhile to first measure the room dimensions accurately and analyze the floor plan to determine the appropriate modules.
Step 1: Decide whether you want to completely visually separate the space or prefer partial openness.
Step 2: Choose modules with open compartments to ensure light permeability, possibly even omitting back panels.
Step 3: Stability is important – therefore, I always recommend connecting the modules to each other and securing them to the wall or floor.
Step 4: By combining flap or door modules, you can conceal storage space.
Tip: Use additional elements such as casters or feet if the room divider needs to remain flexible.
If anyone is unsure, I am happy to help with customized examples!
In addition to the previous comments: Especially if you use Platsa as a room divider, you should pay attention to the height of the modules. Modules that are 180 cm (71 inches) tall are ideal for privacy screening, while 120 cm (47 inches) high modules tend to be more open and provide a sense of spaciousness. For better stability, I recommend not only connecting the modules together but also securing them to the wall with a reinforcement rail. If one side remains visible, make sure that the painted surfaces are durable enough to resist scratches, as a room divider is often used as a seating or storage surface. A nice tip: you can also integrate LED strips into the open shelves to create a cozy atmosphere and highlight the room divider.
