I am currently considering how to best adapt the Ikea Platsa system specifically for a very small kitchen. The kitchen measures only about 2.2 x 2.7 meters (7.2 x 8.9 feet), so storage and efficient use of the available space are absolutely crucial. I am familiar with the basic Platsa modules and find the system generally very flexible, but I am wondering how to best adjust it to tight space conditions, especially regarding:
- Precise fitting to walls with existing recesses
- Use of corners and niches
- Compatibility of cabinet modules in terms of height and depth
- Maximizing storage despite the small floor area
Maybe you have specific tips on combinations that worked well for you or planning tricks that have proven successful in small rooms?
The questioner would appreciate any kind of experience reports or constructive criticism!
Hello DAKOKLO,
your question about the optimal customization of Ikea Platsa for a small kitchen is very practical, as this system’s flexibility is one of its main advantages. I’ll try to highlight some technical details that you should definitely consider during your planning.
First: Platsa modules are available in widths of 60, 80, and 100 cm (24, 31, and 39 inches), with standardized heights (45, 60, 128 cm (18, 24, 50 inches), etc.) and variable depths (37 and 60 cm (15 and 24 inches)). For small kitchens, it makes sense to work with the 37 cm (15 inches) deep modules – this creates more space to move around.
Important points to keep in mind are:
- Accurately measuring your kitchen, including wall recesses and door openings, to fully utilize the maximum cabinet length.
- Using tall cabinets instead of base cabinets can create storage without significantly limiting floor space.
- Adding open shelves (without doors) on the sides of the modules to make corners more accessible.
This works best if you use the IKEA planning software or create a drawing of your kitchen. Platsa can be connected with small connectors, but in corners you might need custom adjustments, such as angled elements or additional small shelves.
I recommend carefully considering interior organization: use drawers, baskets, and adjustable dividers – Platsa offers some clever options here. In the end, it’s about making the most of storage in height and depth.
How are you planning to integrate a countertop? Platsa supports adding worktops, including corner installations.
I look forward to hearing more from you!
DAKOKLO schrieb:
Accurate fit with walls that have existing recesses
DAKOKLO schrieb:
Optimizing storage despite a small footprint
Hey DAKOKLO and Noahlu!
I just wanted to quickly share my enthusiasm for Platsa – it’s really brilliant, especially in small kitchens! 😀
I have a tiny kitchen at home, just under 3x2 meters (10x6.5 feet), and I’ve used the Platsa modules in really versatile combinations. My tip: trust me, the mix of tall and low modules is a game changer!
- Tall ones, for example, are great for pantry storage because they hold a lot without taking up too much floor space
- Low ones work well as drawers for cooking utensils and items you need quick access to
The cool thing is, you can also stack them or partly use them as room dividers if you have an open-plan kitchen-living area.
Plus, with a bit of creativity, you can really make use of every corner – for example, the somewhat narrower 37cm (15 inches) deep cabinets work perfectly in recessed spaces!
Just be bold and experiment; you can’t really mess it up! In my experience, it’s much better to keep working on it and customize as you go than to feel overwhelmed by the small space.
Looking forward to seeing how it goes for you! Good luck!
Teonon schrieb:
Just be bold and give it a try; you really can’t mess it up that badly!I don’t quite agree with that. Especially in small kitchens, a thoughtless combination of Platsa modules can quickly turn into an impractical makeshift solution that offers more tripping hazards than useful storage. Often people just rely on flexibility solving everything, but that’s overly optimistic.
I often notice that the standardized dimensions of IKEA are the reason for suboptimal solutions. If you’re unlucky, the depth might not fit the space, or the height of wall cabinets can be too inconvenient and restrictive. This often results in less usability than if you had a classic, custom-made piece of furniture from the start.
DAKOKLO schrieb:
Compatibility of cabinet modules regarding height and depth There is also a problem here: the modules are indeed combinable, but it often feels like a patchwork quilt. In the end, what matters is how the kitchen functions, not how many parts it has. You shouldn’t be dazzled by the possibilities.
My advice: Especially with small kitchens, you have to prioritize clearly and sometimes it’s better to opt for custom-made furniture instead of relying too much on prefabricated solutions – and that applies to Platsa as well.
