ᐅ Are there compact IKEA PLATSA solutions suitable for small apartments?
Created on: 13 Dec 2024 08:17
Josh68
Josh68
13 Dec 2024 08:17
Are there compact IKEA PLATSA solutions for small apartments?
I will soon be moving into a very small apartment, which mainly consists of a single room. My challenge is to create as much storage space as possible without the furniture feeling too bulky or taking up too much space. IKEA PLATSA seems very flexible and customizable, but I wonder if the system actually offers good, practical, and compact solutions for very small rooms.
Can you share your experiences regarding layouts, combinations, or designs that have worked well? I am especially interested in things like built-in cabinets with storage that blend seamlessly into the room, as well as options that serve both as storage and as a design feature.
It would also be helpful to know if the PLATSA system is easy to assemble for someone with little experience in furniture assembly, and if it is sturdy enough for everyday use in a small apartment.
I appreciate any tips and advice!
Davidleo
13 Dec 2024 09:45
Wow, your topic is right up my alley! I have a small studio apartment myself and have been using PLATSA for over a year. The system is really brilliant! 😃
What I really like: The modules are very flexible, so you can practically adjust them to any wall size. I built a combination of tall and low cabinets, which creates a lot of storage space without feeling overwhelming.
A little tip: Make sure to install the wall cabinets above the bed – that way you use space that would otherwise be wasted! And for assembly: IKEA provides great instructions, so you can manage even without being a professional. If you run into problems, just ask here on the forum, we’ll help quickly!
Good luck, you can do it! And feel free to reach out if you have any questions 🙂
koduga
13 Dec 2024 11:02
I can understand how challenging it can be to fit everything into a small apartment. You often feel cramped, and finding functional furniture can be a real test of patience.
What I appreciate about PLATSA is the ability to create customized solutions tailored specifically for small spaces. I personally had trouble making the most of the available space and, while searching for practical storage ideas, I found that the flexible modular system often provides a good solution that also looks visually appealing.
Maybe you could tell us more about your specific room situation? I’m especially interested to know if, for example, you have a niche or particular wall areas installed that you want to use efficiently.
Kinbu
13 Dec 2024 11:56
Hello Josh68,
your question is very well formulated and shows that you have already thought about the practical implementation. I would like to add something:
PLATSA works excellently when you know the exact dimensions of your room and plan accordingly. The modules can be adjusted in height, width, and depth, allowing them to fit small spaces without making you feel cramped.
- For small apartments, I often recommend a combination of low sideboards and tall cabinets to create an open feel.
- If you have wall space, wall shelves can also be included to keep the floor area free.
- It is important to choose doors and drawers that do not get in the way in a small apartment.
The assembly is manageable for many. If you have difficulties, it is best to work with at least two people and carefully follow all the assembly steps.
Do you also want to use the system in rental apartments without extensive drilling? This is also important for flexibility.
lisku
13 Dec 2024 12:30
PLATSA is well suited for small apartments because it can be customized to fit perfectly. Use tall cabinets on narrow walls and open shelves to avoid overwhelming the space. Assembly is achievable for anyone with the instructions.
blapau
13 Dec 2024 14:47
For small rooms, PLATSA is indeed suitable, provided that the room dimensions are measured accurately. The modular design is a major advantage, allowing for flexible planning.
I recommend:
- Storage space behind doors that open in a space-saving way (e.g., sliding doors, if available)
- Using depths between 35 and 40 cm (14 and 16 inches) to keep the units compact
- Combining with multifunctional furniture, such as seating areas that offer additional storage
The build quality is also solid, making it perfectly suitable for everyday use.
