ᐅ How can Ikea PAX wardrobes be used for storing electronic equipment?
Created on: 29 Nov 2023 16:43
Thales67
Thales67
29 Nov 2023 16:43
I have been thinking about how to better use my Ikea PAX wardrobe for storing technical hardware. It’s not just about simple storage, but also about organizing cables, power adapters, small devices like NAS units, routers, or even oversized power banks.
My question is: How can Ikea PAX wardrobes be optimally designed and equipped so that technology is stored neatly, securely, and remains easily accessible when needed? Are there specific inserts or tricks for ventilation and cable management that can turn the wardrobe into a practical tech hub?
I would appreciate any experiences, ideas, and possibly recommendations for suitable accessories.
fredle
29 Nov 2023 18:27
Good question, there are actually several useful approaches to preparing a PAX wardrobe for technical equipment.
First, ventilation is crucial, especially if you use devices with active cooling. I recommend installing ventilation grilles or at least using partially perforated doors. Small USB fans can also be added to ensure continuous air circulation.
Next, cable management: it’s best to use cable ducts or clips on the back panels. If the PAX back panel is made of wood, cable openings can be created with a router. Another great advantage is using drawer runners or boxes to store chargers and power supplies so they don’t lie around untidily.
Regarding inserts: there are modular inserts, such as boxes or small shelves, that can be stacked within the PAX height. Metal shelves are also useful for creating sturdy surfaces that can support the weight of technical equipment.
Summary:
- Ventilation grilles or active ventilation
- Cable openings or ducts on back panels
- Drawer runners for organization
- Small modular inserts or boxes
Common mistakes are mainly missing ventilation and inadequate planning regarding weight or cable accessibility. The most frequent pitfall is just shoving everything in somewhere and later hardly being able to reach it.
Tobias
29 Nov 2023 19:05
Simply install power strips with surge protection and use cable ties. Ventilation is only necessary for powerful devices. For NAS, shelves with sufficient load-bearing capacity are important.
Curtis
30 Nov 2023 10:39
However, this needs to be carefully considered. An open or perforated cabinet does not protect well against dust, which can be problematic for electronics. In this case, a filtering system with dust protection would be advisable.
Tobias schrieb:
You only need ventilation for high-power devices.
Caution is also necessary here. Many NAS units or routers do generate heat that can quickly build up in a closed space. Even passive ventilation might be insufficient.
I would suggest distributing the equipment modularly inside the PAX and planning targeted holes in the side panels for air intake and cable passages. Not all devices should be placed directly next to each other to reduce heat buildup.
Additionally, clarify in advance how you will manage access for maintenance and connections; otherwise, the cabinet can become a technology graveyard.
PeoDaniel
1 Dec 2023 08:12
Another helpful idea is not only to store your equipment neatly but also to make it ergonomically accessible. For example, the PAX cabinet doors can be fitted with internal compartments where smaller devices and cables can be organized clearly.
Mounting power strips with on/off switches in an easily reachable spot inside the cabinet is also very useful for turning devices on and off without the hassle of unplugging and plugging them back in.
If you plan to use the PAX as a real technology hub, make sure to remove the back panel of a compartment or replace it with one that has cable openings. This makes cable routing easier and allows for a tidier arrangement behind the devices.
Finally, always allow enough space for heat dissipation and position your equipment so that displays and connectors remain easily accessible, especially for frequently used devices like Wi-Fi routers or streaming boxes.
I hope this helps you further.
barle
1 Dec 2023 15:52
I use simple plastic boxes and cable ties to keep everything organized. Cable grommets are important, otherwise it quickly becomes messy. Ventilation is only necessary for devices that become noticeably warm.
