ᐅ How can Ikea Pax wardrobes be transported without damage during a move?
Created on: 9 Mar 2024 08:37
Galip38
Galip38
9 Mar 2024 08:37
I am about to move and plan to transport my Ikea Pax wardrobe to the new apartment with as little damage as possible. As you probably know, Pax wardrobes are quite large and consist of several individual parts, some of which are quite delicate and have sensitive surfaces.
My specific question is: What is the best way to prepare, pack, and transport the Ikea Pax wardrobe during a move to avoid scratches, dents, or other damage? Are there proven techniques or materials to safely disassemble and reassemble the wardrobe? And what should be taken into special consideration regarding the doors, drawers, and side panels?
I would appreciate detailed tips on preparation, packing methods, and the transport process itself – especially if anyone has experience handling Pax wardrobes during moves. Thanks in advance!
Santi
9 Mar 2024 09:02
Hi,
It’s best to carefully disassemble all parts and pack the doors separately using bubble wrap or blankets. Empty the drawers and transport them separately. Protect the side panels with cardboard to prevent them from banging against each other. If possible, store everything flat and avoid stacking heavy objects on top.
gregto
9 Mar 2024 11:46
Hello Galip38,
your question makes a lot of sense, as a Pax wardrobe really requires considerable effort when it comes to safe transportation. Here is my recommendation:
- First, be sure to completely disassemble the wardrobe, separating the carcass into side panels, shelves, and back panels. The large panels are usually delicate, so wrap them first with thick blankets or bubble wrap.
- For the doors, I use especially thick blankets or felt protectors to avoid scratches. Store the doors flat and try not to lean them against walls.
- Do not transport drawers with contents inside; empty them completely. Pack the inner parts in small boxes and transport them separately.
- Put screws and fittings into small bags and label them with a photo or note indicating what they belong to.
- During transport, store all parts as flat and tightly packed as possible to prevent shifting. If the van stops frequently, secure the parts with straps immediately.
- I would recommend taking photos before disassembly to make reassembly easier.
If you have any questions about specific wardrobe parts, feel free to ask!
Dopoki
10 Mar 2024 07:29
GALIP38 schrieb:
The Pax wardrobes are well known for being quite large and consisting of several individual parts, some rather delicate with sensitive surfaces.
That’s true. The special feature of Ikea Pax wardrobes is mainly the particleboard material used, which can swell when wet and is easily damaged at the edges. Therefore, the following points must be strictly observed during transport:
- Use completely dry components;
- Apply edge protection made of foam or cardboard on all corners;
- Use special padding for doors with glass or mirror elements;
- Remove drawers and doors completely and store them separately;
- Avoid strong shocks and impacts during transport.
Additionally, it is recommended to place the parts in a sturdy, preferably padded outer packaging. This protects against dirt and mechanical stress. For self-organized transport, the parts must not be stacked loosely on top of each other but must be securely strapped down.
From my experience, disassembling and packing the parts separately with associated small components in labeled bags is essential to avoid surprises during later assembly.
GALEO4
11 Mar 2024 16:13
gregto schrieb:
If you have any questions about specific cabinet parts, feel free to ask!
Regarding "damage-free": I think the whole effort is often exaggerated. Of course, you protect every edge, cushion everything, and eliminate any gaps. But in everyday situations, especially during moves where space is tight, some minor incidents are almost inevitable.
My provocative take: it might be better to handle the cabinet a bit more roughly and accept small scratches or dents during assembly, in exchange for making the move less stressful. What do you think? Does every component really need to be individually and meticulously protected, or is a solid basic protection with blankets and straps enough?
This is not a recommendation, just something to think about.
