ᐅ How can the Ikea Pax system be reinforced for heavy loads?
Created on: 24 Aug 2020 09:43
LUFO32
Hello everyone, some time ago I bought an Ikea Pax wardrobe, which is basically very practical. However, I have noticed that under heavier loads – for example, when many heavy garments or boxes are stored inside – the system’s stability reaches its limits. I’m not just talking about a slight wobble when touching it, but also a noticeable strain on the back panel and the supporting brackets, which is starting to concern me.
My specific question is: How can the Ikea Pax wardrobe be made more stable and durable under heavy loads without immediately becoming a professional furniture maker or replacing the entire unit? Are there proven methods, additional reinforcements, modifications, or special accessories that I can use to keep the wardrobe stable and prevent any deformation or damage? I’m especially interested in tips that are not only theoretical but have been successfully applied by others.
Thanks for your help!
Dopoki
25 Aug 2020 08:33
A practical approach is to systematically reinforce the main load-bearing points.
- Hardwood battens approximately 20 x 40 mm (0.8 x 1.6 inches) should be installed across the width under the shelves to prevent sagging.
- For heavy loads in lower sections, it is advisable to install a vertical center support, ideally screwed to the back panel.
- Drawer slides should be checked and replaced with versions certified for load capacities of at least 20 kg (44 lbs).
- Finally, the cabinet must be securely anchored to the wall by a professional to prevent tipping and ensure stability.
These measures, combined with dimensions appropriate for the cabinet, ensure lasting reinforcement.
ixlu1
25 Aug 2020 10:11
Great topic here, the Pax can be really upgraded!
I would definitely not skimp on the materials and try building your own reinforcements – from my experience: new thicker shelves made of plywood or MDF that you have cut to size at the hardware store. Then secure them under the shelves with metal angle brackets.
A tip: this not only makes the cabinet sturdier but also more durable – and you’ll really enjoy the project. And trust me: the feeling when the cabinet is absolutely stable is worth all the effort!
Kabau
25 Aug 2020 13:49
It is important to secure the wall properly and use additional metal brackets on the sides and corner joints. This effectively prevents wobbling and is cost-efficient.
floga
26 Aug 2020 07:57
It’s understandable that stability is important to you—many others have experienced the same concerns. I used to have similar worries and often tried to create small reinforcements myself. Sometimes it also helps not to pack the cabinet all the way to the edges and to store heavier items at the bottom, which can reduce stability issues somewhat.
If the cabinet ever wobbles or creaks, that can also be psychologically stressful. That’s why I think it’s great that you’re proactively seeking information here. Your caution shows good furniture sense and a long-term perspective.
Seanni
26 Aug 2020 12:03
Ryker66 schrieb:
I always used additional metal brackets on the corners of my Pax, especially at the bottom.
+1, the lower corners are often weak points! And if you choose brackets that are large enough, you can distribute the load really well.
Kabau schrieb:
Wall mounting and additional metal brackets on the sides and corner joints are important.
I totally agree, this combination is like a joker! Also, I used some foam at the contact points between the cabinet and the wall to prevent noise from even slight vibrations. Works great if you’re familiar with that issue.
