ᐅ How can Ikea Hemnes furniture be protected from wear and tear?
Created on: 29 Jun 2022 08:42
ixpiflo
ixpiflo
29 Jun 2022 08:42
I recently purchased several pieces of furniture from the Ikea Hemnes series and am now considering the best ways to protect them from wear and tear. My main concerns are scratches, visible signs of use, and possible discoloration caused by sunlight or moisture.
The Hemnes furniture is made from solid wood (spruce) or at least has a natural surface finish, so I assume that proper care and protection are especially important to ensure longevity. I am therefore interested in which specific care methods and protective measures you consider effective for keeping the furniture in good condition for as long as possible.
Are there any particular products you would recommend? How often should they be applied? And how can one avoid potential damage from using the wrong cleaning or care products? Practical tips such as covers, pads, or preventive measures against water rings and wear marks are also very welcome.
I look forward to your experiences and advice!
PLOMA
29 Jun 2022 13:07
Hello ixpiflo,
first of all, a very good and precise question, which also takes into account the specific characteristics of the Hemnes furniture. Since these pieces are usually made of painted solid wood (mostly spruce), the surface is susceptible to mechanical damage such as scratches, as well as moisture damage.
A structured approach to avoid wear could look like this:
- Cleaning: To remove dust and dirt, use only slightly damp cloths, no aggressive cleaning agents, as they can damage the paint.
- Surface protection: Special furniture polishes or water-based waxes are well suited here, as they form a thin protective layer. However, these should only be applied every few months to avoid building up layers and causing edges.
- Mechanical protection: Coasters, felt pads for chair and table legs, as well as avoiding direct contact with sharp or heavy objects, significantly reduce stress.
- UV protection: Since UV radiation can fade wood and paint, it is advisable not to expose furniture to direct sunlight permanently. If unavoidable, special UV protection films for windows offer a way to limit the damage.
- Moisture protection: Avoid water rings by always using coasters. React quickly to spilled liquids to prevent moisture penetration.
- Repair: For small scratches, there are special furniture markers or wax pastes that can conceal damage.
I would be interested to know if you already have a specific room or type of furniture from the series in mind? Depending on the use, the strategy may vary. What about you?
JEREMIAH38
30 Jun 2022 09:21
I also consider this protective layer very important, especially since I’ve personally felt that Hemnes furniture tends to wear relatively quickly if you don’t take the right precautions.
I had a similar experience to ixpiflo – some time ago, I bought a Hemnes sideboard and a desk from this series and unfortunately noticed that after only a short time of use, small scratches and dull spots appeared, which annoyed me quite a bit.
What helped me is regular, gentle care with furniture oil or wax specially designed for wooden furniture. It was important for me not to apply too much to avoid sticky residues. I also always use felt pads under vases and other decorative items.
A small tip: if someone has pets, it’s especially important to prevent quick scratches on Hemnes furniture – in such cases, a protective film or a water-based sealant can definitely be useful.
I think discussions like this are really helpful for learning from each other and encouraging one another – after all, everyone wants to keep their furniture looking good for a long time.
draleo
1 Jul 2022 10:45
To continue the discussion with a factual overview, I will summarize the key points and add specific recommendations:
- Material properties: Hemnes furniture is generally made of painted pine wood. Although paint provides protection, mechanical stress such as scratches or impact marks can damage the surface.
- Cleaning and maintenance: Avoid aggressive cleaning agents or strongly alkaline substances. Instead, use mild soap solutions or specialized wood furniture cleaners that leave no residue. The use of wax or oil is possible, but only if the surface is appropriately unfinished or glazed, which is often not the case with Hemnes, as it is usually painted.
- Mechanical protection measures: Felt pads on furniture legs, coasters for glasses and vases, as well as avoiding direct contact with metal objects, significantly reduce scratches and wear.
- UV protection: Prolonged exposure to high levels of UV light can alter the surface color. Insulating window films or consciously placing the furniture away from direct sunlight can help.
- Cleaning frequency: The surface should only be cleaned when necessary, avoiding excessive moisture. Dry the surfaces immediately after cleaning to prevent water damage.
- Repair: For small paint damages, professional repair kits that match the paint color precisely are suitable.
If anyone has detailed information about the types of paint used or cleaning products previously applied, we could make these recommendations more precise. Otherwise, as a basic rule: protect, clean carefully, avoid mechanical stress and sun exposure.
