ᐅ Are there any issues with using IKEA Hemnes furniture in damp or humid rooms?
Created on: 14 Sep 2022 08:17
Klaburkard
I am planning to use the IKEA Hemnes furniture range in a damp room, specifically in a bathroom with high humidity but no direct water splashes. My question is quite specific: Are there any known issues or experiences regarding the use of Hemnes furniture in such damp environments?
I am particularly interested in possible material changes caused by moisture, such as wood swelling, warping, paint problems, or the durability of hardware under these conditions.
If anyone has already used the Hemnes range in a bathroom or is knowledgeable about the materials and their suitability, I would greatly appreciate well-informed advice or alternative suggestions. Thank you!
I’d like to add that the Hemnes furniture is made of solid pine, which is quite sensitive to moisture if it hasn’t been specially treated. In a bathroom with regular ventilation, the furniture might hold up, but without proper airflow or if it stays damp from water splashes, long-term damage can occur.
The painted surface of Hemnes provides some protection but is not necessarily waterproof. In a similar setup, I applied an additional clear lacquer layer to reduce the risk.
Another point to consider: joints and seams can absorb moisture, which may weaken stability. Regular inspection and re-treatment when necessary are advisable.
If you’re dealing with moisture issues in the bathroom, it might be worth choosing furniture specifically designed for humid environments or at least using wooden furniture in areas that stay drier.
From a factual perspective, the IKEA Hemnes range is not designed for long-term use in humid environments due to its material composition and surface treatment.
- Material: Solid pine, which is naturally hygroscopic and swells when it absorbs moisture.
- Surface: The paint provides some protection but does not offer a permanent moisture barrier.
- Fasteners: Metal fittings tend to rust without special corrosion protection coatings.
If used in a bathroom, adequate ventilation is essential. Additionally, applying an extra sealant (e.g., clear varnish) can extend its lifespan.
Alternatively, furniture specifically made for damp rooms, such as those constructed from coated particleboard or plastic, is recommended.
FLONE41 schrieb:
I have Hemnes furniture in the guest bathroom, which is not well ventilated. After about a year, I noticed slight warping on the cabinet, especially at the corners.This exactly confirms what I suspected.
Even though Hemnes appears to be high quality, its pinewood base is very sensitive to moisture. If the room is poorly ventilated, warping is common. The only solution is to choose furniture that is more moisture-resistant.
An additional tip: avoid placing the furniture directly on the floor, as this improves air circulation and reduces the risk of moisture absorption on the underside.
Klaburkard schrieb:
Are there any known issues or experiences regarding the use of Hemnes furniture in such damp rooms?Yes, the furniture tends to swell, the paint peels off, and screws can rust. Not suitable for long-term use in bathrooms.
To conclude from my side: I would only recommend Hemnes for use in damp rooms with significant reservations, if you are willing to invest time in maintenance and protection.
If you still want to use the furniture, regularly check for early signs of damage and try to protect the furniture as best as possible from direct moisture.
It’s frustrating because the design is great, but the material properties simply are not suited for bathrooms. This is the case with many wooden furniture pieces, not just Hemnes.
