ᐅ How can IKEA Hemnes be made safe with anti-slip pads?
Created on: 16 Aug 2024 14:23
Ruisin
Ruisin
16 Aug 2024 14:23
I am currently looking into the safety of my IKEA Hemnes chest of drawers, specifically the large 8-drawer version, which is relatively stable but can still be a bit slippery on smooth floors. Therefore, my question is: How can you effectively secure an IKEA Hemnes chest of drawers with anti-slip pads to prevent it from sliding or tipping over? I am particularly interested in suitable methods or product recommendations for attaching the pads that adhere well but can also be removed without damaging the surface of the Hemnes.
Does anyone have practical experience with which types of anti-slip materials work best? And what is the most effective way to attach the pads so they don’t move under load (for example, when opening drawers or moving the chest)?
I look forward to your tips and advice!
Dilen
16 Aug 2024 15:06
Hey Ruisin,
I find your question very interesting because stability and slip resistance for furniture are much more important than many people realize, especially with the Hemnes series, which often requires a fairly smooth floor surface to avoid slipping too easily.
Regarding the use of anti-slip pads, I recommend choosing materials with a high coefficient of friction, such as soft rubber or silicone pads. These can either be in the form of small self-adhesive pads applied under the furniture legs or as square anti-slip mats cut to size if the contact area is larger.
Technically, when installing them, you should keep the following points in mind:
- The surface of the dresser and the floor must be clean, dry, and free of grease. It’s best to pre-clean lightly with alcohol.
- Apply the anti-slip pads where the ball feet or edges of the Hemnes dresser touch the floor.
- Make sure the adhesive surface is large enough so the pad doesn’t slip or come off under load.
- If you want something more permanent, there are also rubber feet or felt-coated triangular stoppers that can be screwed under the legs, but this is usually difficult with the Hemnes due to its construction.
Could you also let us know what type of floor the dresser stands on? Hardwood, laminate, tiles? This also plays a big role in which pads work best. Sometimes combinations make sense, such as anti-slip felt with a rubber backing.
I hope this helps you so far!
KNUTGI
16 Aug 2024 15:57
Hello everyone! 😄
I had to smile when I read "making IKEA Hemnes safe with anti-slip stoppers" – as if a wobbly dresser isn’t adventure enough in everyday life!
But seriously: especially with furniture like the Hemnes, which is really large and sturdy but can slide across smooth floors like little race cars, flexible, self-adhesive rubber pads are a great solution. Personally, I find those small black rubber pads brilliant—they stick under the feet almost like slippers for the dresser. They aren’t too thick, hardly affect the look, and are also very easy to remove without leaving adhesive residue.
Besides being effective, they are nearly silent, which is great when the dresser is moved. And still, they can hold a considerable amount of weight without slipping.
Just a quick tip: when installing, don’t rush to stick them on; better to align properly once, press firmly, and then wait a bit for the adhesive to set. That way, the pad really grips. Looking at it humorously: your dresser wants to stay put, just like we don’t want to slide off our chair while enjoying a good morning coffee! 😉
What do you think? Or does anyone have alternative, maybe even cooler ideas?
blapau
17 Aug 2024 09:47
Good morning,
to round off the topic here with some technical insights, I would like to add a few practical facts that have proven effective.
First, it makes sense to match the size of the non-slip pads to the contact area of the dresser feet. For the Hemnes dresser, the feet are usually quite small and rectangular, so flat rectangular pads work better than small round ones.
Second, make sure that the material of the non-slip pad is suitable for your flooring. For sensitive wooden floors, products without water-repellent silicone particles are recommended, as these can damage the sealant.
Third, positioning is crucial. The pads should be evenly placed on all four corners to prevent tipping. For a tall dresser like the Hemnes, it can also be helpful to add small non-slip strips to the middle shelf if needed, to keep the dresser stable and prevent it from wobbling when pulling out drawers.
An additional safety feature could be to use furniture anchors or angle brackets to secure the dresser to the wall. While this is not a direct solution involving non-slip pads, it increases safety around children or during earthquakes.
If you want to know which adhesives or installation methods to avoid, I can also provide tips on that.
I look forward to hearing if these additional suggestions are helpful to you.
