ᐅ How can you effectively adapt Ikea Hemnes furniture for use in a rental apartment?
Created on: 1 Feb 2024 10:38
munapinHello everyone,
I’m moving into a new rental apartment and own several Ikea Hemnes furniture pieces, including cabinets and dressers. I’m now facing the challenge of adapting these Hemnes items to the conditions and restrictions of the rental without causing any permanent changes or damage.
I’m especially interested in:
- How can the furniture be best adjusted to fit different room sizes?
- What options are available if you’re not allowed to use nails or screws on the walls?
- Are there proven methods to improve the stability of the furniture when space is limited or walls are uneven?
- Which useful accessories or modifications from Ikea or third-party suppliers do you recommend to make Hemnes furniture more functional for a rental?
I look forward to tips, experiences, and solutions that might have helped you in similar situations. Thanks in advance!
There are a few effective methods for adapting Ikea Hemnes furniture in a rental apartment:
- Instead of drilling screws or nails into the wall, I recommend using non-slip adhesive pads or furniture rails specifically designed for rental properties.
- For uneven walls or floors, height-adjustable furniture feet or silicone pads provide a simple solution to ensure stability.
- Space optimization can often be achieved by rearranging or adding Hemnes shelves or narrow units to better utilize corners.
- Accessories like clamp-on protective strips or rear covers enhance safety and prevent damage to the furniture.
In general, solutions should be reversible to avoid damage when moving out. If you need to change the color of the furniture, special removable films or wood paints that leave no residue are advisable.
If you have questions about specific furniture parts, I am happy to provide more detailed information.
I would approach this topic from a more technical perspective, as rental restrictions are often underestimated.
First, it is extremely important to carefully check the structural conditions of your apartment:
- What are the walls made of (drywall, masonry)?
- How level are the floors exactly?
For Hemnes wardrobes and dressers, I recommend the following approach for adjustments:
1. Stabilization without wall mounting:
- These wardrobes usually have back panels made of thin plywood. You can increase stability by installing sturdy wooden strips inside that reinforce the frame.
- For floor leveling, adjustable furniture glides with rubber coating are suitable; this prevents wobbling and at the same time protects the floor from scratches.
2. Downsizing or adapting for small spaces:
- Hemnes furniture can be minimally modified by removing back panels or changing the fronts. For example, you can remove doors and turn them into open shelves.
- Alternatively, use smaller Hemnes units combined with top cabinets or shelving.
3. Assembly without drilling holes:
- Use transparent tension straps or furniture rails that rest on the furniture and clamp to the ceiling or wall, allowing you to achieve stability without drilling into the wall.
4. Visual adaptation:
- Hemnes can be easily modernized with gray or white furniture paint without risking the original condition when moving out.
Could you provide more details about the exact room situation and the furniture dimensions? What kind of restrictions are there specifically with the landlord?
Domau0 schrieb:
Could you provide more details about the exact room layout and the furniture dimensions? What specific restrictions do you have with the landlord?This is a very important question. For optimal advice on adapting Ikea Hemnes furniture in a rental apartment, it is always essential to know the exact local conditions.
In general, here is a brief guide on how to adapt Hemnes furniture sensibly without causing permanent damage:
- Planning: First, measure all dimensions of the rooms and furniture accurately. Often, furniture can be better adapted by removing doors or installing shelves.
- Installation aids without drilling: Adjustable tension devices or additional furniture legs can provide stability.
- Modular additions: The Hemnes series offers toppers, shelves, and drawers that can also be added later.
- Protecting the rental property: Use felt pads, non-slip mats, and reversible installation aids.
If possible, always obtain written permission from your landlord before drilling—sometimes they are more flexible than expected.
I am happy to assist with the detailed planning if you provide more information about your room layout.
