ᐅ How can IKEA Besta be flexibly combined with wine crates?
Created on: 26 Dec 2023 14:07
pilen
Hello everyone, I’m currently exploring how to flexibly combine the IKEA Besta system with wine crates. My idea is to create a modular furniture set that offers both storage and decorative elements. I’m particularly interested in ways to connect the typical Besta components – that is, carcasses and fronts – with wine crates of various sizes in a way that doesn’t look unstable or awkward.
In which rooms does this kind of combination make the most sense? Are there proven mounting methods to securely integrate wine crates in or on the Besta system? And how can the whole setup be designed to remain flexible, so that additional crates can be added or rearranged later on? I’m also open to experiences regarding visual combinations, for example in terms of colors and materials. Thanks in advance for your tips!
Filippo
27 Dec 2023 14:54
To address "fixing without screws": for flexible yet stable connections, I recommend using hook-and-loop fasteners or magnetic solutions, which are often used in custom-made furniture but are also suitable for DIY projects.
- Magnetic holders: Small neodymium magnets can be embedded on the sides of crates and the Besta frame, so that the crates can be removed when needed but still stay securely in place.
- Hook-and-loop strips: Heavy-duty hook-and-loop strips applied on contact surfaces prevent slipping but can be easily separated when necessary.
For visual harmonization: I successfully sealed natural wine crates with clear varnish and then outlined the edges with black acrylic paint—this gives a modern touch and coordinates well with the matte black edges of the Besta units.
For arrangement, it is advisable to leave about 2 cm (1 inch) of space between the wine crates and the Besta frames and to use rubber feet on the bottom of the crates to create a small gap from the floor, achieving a "floating" design.
How do you envision using the crates—solely for storage or do you want to use them as drawers as well?
likuken
28 Dec 2023 11:13
pilen schrieb:
I would appreciate any tips on “fixing without screws” or “visual matching.”
Fixing without screws is often just marketing for “we don’t want to force the customer to use screws.” Sorry, but there are hardly any better methods than screws or at least strong adhesive bonds if you want flexibility and security.
Visually, that presents a real challenge: wine crates tend to be rustic, while Besta units are rather minimalist. If you don’t mind a contrast, you can of course leave it as is, but combining a cozy and modern look at the same time will be difficult.
My advice: if you want genuine design, invest in better plywood boxes that are easier to customize instead of relying on wine crates.
Otherwise, you’ll have to compromise on either aesthetics or functionality.
barle
28 Dec 2023 17:22
Simply paint the wine crates to better match Besta. Screws are quick to use and hold securely. For stability, use screws.
