I am considering using my Ikea PAX wardrobe systems for tool storage and organization in my hobby workshop. My goal is to redesign the cabinets to be as functional as possible, so I can store all kinds of tools—from screwdrivers and power tools to woodworking and metalworking tools—efficiently and in an organized way. I am particularly interested in practical tips regarding interior fittings, compartmentalization, reinforcement, and accessories that are compatible with PAX.
Are there any specific experiences or recommendations on how to best repurpose Ikea PAX for tool storage, for example concerning load-bearing shelves, additional inserts, lighting, or space-saving solutions?
I find the PAX construction very flexible, but I am not sure how suitable the load capacity and design options are for rather heavy tools. I would appreciate any advice that helps to make the system robust, practical, and well-organized.
Thanks in advance!
Thanks in advance!
Hello ralfba,
First to the core topic: Ikea PAX is a modular wardrobe system that can be adapted quite well to a workshop environment through flexible interior fittings. Some important points to consider are:
- Load capacity: The standard shelves of PAX hold about 25 kg (55 lbs) each. For heavier tools, it is advisable to use additional supports or stronger shelf boards (e.g., plywood panels).
- Interior fittings: Ikea offers drawers, boxes, and inserts, but more affordable options include metal toolboxes or custom-made inserts that can be installed inside the PAX units. Especially sturdy drawer inserts or sorted boxes are useful.
- Mounting: Tool holders can be attached to pegboards or hooks. Since PAX does not have integrated pegboards, you can either hang pegboards on the inside of the doors or build your own constructions using wooden slats and screw-in hooks.
- Lighting: There are plug-in LED strips that can be installed inside the PAX units. These improve visibility.
Your assessment of the flexibility is correct. I recommend starting by measuring which tools you use and how often, then planning the interior fittings accordingly.
For heavy equipment, I suggest dedicating one cabinet section mainly for storage and equipping others with drawers. This helps maintain stability.
I’m happy to help with detailed questions on implementation.
gaubla schrieb:
Ikea PAX is a modular wardrobe system that can be adapted to a workshop environment through flexible interior fittings.Absolutely, I agree! I equipped my PAX wardrobes with purchased sorting boxes and magnetic tool holders – they hold really well and look very neat.
The most important thing is to use the space efficiently and avoid storing everything loose! It’s a lot of fun once you have a setup tailored specifically to your tools. Don’t be afraid of modifications! The PAX units are very sturdy, and with a few tricks, you can significantly increase their load capacity.
A small suggestion: consider using hanging systems on the inside of the doors, as they can surprisingly hold a lot.
Keep at it, and good luck with your project!
ralfba schrieb:
Are there any specific experiences or recommendations on how to best repurpose Ikea PAX for tool storage, for example regarding sturdy shelves, additional inserts, lighting, or space-saving systems?Hi ralfba,
I use the PAX in my garage for organizing tools and can add the following points:
- Use plywood or multiplex panels as shelves placed on the PAX brackets. These are significantly stronger than the standard shelves and can hold heavy equipment.
- For small items, clear plastic boxes with lids are worth it; you can stack them or integrate them into drawers.
- Attach pegboards or custom foam inserts to the inside of the doors for hand tools like wrenches or pliers.
- Installing LED light strips with motion sensors makes working easier, especially if the cabinet is placed in a corner.
It’s important to take precise measurements before fitting interior components to ensure everything fits.
I can also provide advice on specific materials if needed.
