ᐅ How can I stabilize Billy shelves if they wobble?
Created on: 30 May 2015 18:03
milelis
I have several Billy bookcases at home, which unfortunately can sometimes be a bit wobbly, especially when handling them roughly or pulling on them. I have already checked that all the screws are properly tightened, but the problem remains. I understand that the Billy bookcase is not a solid wood cabinet, but I want to avoid it becoming completely unstable or damaged.
My question to you is: How can I stabilize my Billy bookcases if they wobble? Are there any proven tips or simple methods that can be used without having to completely rebuild the structure? Is there perhaps even a way to improve stability using common tools or materials?
I look forward to your advice and experiences!
manla
1 Jun 2015 09:11
Hello again,
a quick addition to my earlier posts: If you attach the back panel with stronger nails or screws, I recommend distributing the forces evenly, so don’t place all the nails along just one edge. The back panel should act like a board that braces the entire frame.
Also, make sure none of the screws are over-tightened. This can easily happen with the thin panels that Billy uses.
Regarding wall mounting: Some people have reported securing the shelf to the wall with heavy-duty anchors when storing very heavy items. However, this is usually not necessary for normal use.
Best of luck with stabilizing it!
milelis
2 Jun 2015 14:58
I just wanted to thank you again for the support. Over the weekend, I checked everything, tightened the screws, re-nailed the back panel a bit, and attached the supplied wall brackets to my drywall using suitable toggle anchors. Additionally, I placed small felt pads under the feet to compensate for unevenness in the laminate flooring.
The result: The shelf is now really stable, with hardly any wobbling—I am very satisfied.
Thanks again to everyone for the many tips and detailed advice. It was definitely worth approaching the project carefully!
minjan
2 Jun 2015 15:12
Glad to hear it’s working well now. Enjoy your sturdy Billy shelf!
GIPAPO
2 Jun 2015 15:32
Good to hear that everything turned out well. Wall mounting is simply the best advice.
