ᐅ How can I set up Ikea Platsa for a home office?
Created on: 5 Apr 2021 08:32
O
onjekau
O
onjekau
5 Apr 2021 08:32
I am planning to set up my home office using the Ikea Platsa system and would like to know the best way to use this modular furniture concept to create a functional and well-organized workspace. I am particularly interested in the following points:
- How can I combine the cabinets and shelves to provide enough storage space for documents, office equipment, and accessories?
- Are there any tips for making the best use of the back panels and doors, for example, for cable management or mounting options?
- How can I design the workspace ergonomically with Platsa to stay productive despite limited space?
- Which combinations of Platsa furniture work especially well for small rooms or work niches?
I would appreciate concrete furnishing suggestions or experiences, especially how you have implemented the system in a home office to create a pleasant yet practical working environment.
Thank you in advance!
liskar
5 Apr 2021 10:14
The combination of Platsa cabinets offers a lot of flexibility thanks to its modular design. For a home office, I recommend the following basic setup:
- Use the lower cabinets with drawers or doors as storage for folders, printers, and technical equipment.
- Upper open shelves are ideal for frequently used office supplies or decorative items.
- The back panels can be used with board systems (with matching hooks) to neatly route cables or attach small accessories.
- For ergonomic work, desk tops (sold separately) at about 72 cm (28 inches) height are recommended, combined with an adjustable office chair.
- In small rooms, a combination of lower cabinets and vertical use with taller modules makes sense to save space.
Platsa is well suited because it offers different depths and shapes of modules that can be flexibly adapted to the room.
Palenar
6 Apr 2021 19:27
onjekau schrieb:
How can I combine cabinets and shelves to ensure enough storage space for documents, office equipment, and accessories?
As a general recommendation, start by clearly identifying which items you need on a daily basis during work and which are used less frequently. For daily use, open compartments or containers with easy access are important, while documents or infrequently used devices can be stored behind doors or in drawers to maintain a tidy appearance.
- Use the different depths (35 cm (14 inches) and 55 cm (22 inches)) of the Platsa modules purposefully. Deeper cabinets with metal shelves are ideal for file folders because they can better support the weight.
- Cable management: The back panels of the Platsa modules are perforated or can be drilled, allowing you to install a flexible system of cable clips, cable channels, or small shelves. This keeps charging stations and power strips neatly organized.
- Ergonomics: Keep in mind that the Platsa tabletop is not height-adjustable. Therefore, a good office chair to accommodate individual sitting height is essential. A monitor stand can also help optimize the line of sight.
- Small niches: If you work in a corner, corner modules can use the space very efficiently. Just make sure access to all cabinets and drawers is not obstructed.
What size room do you have available? Providing exact dimensions will help to give even more tailored recommendations.
liskar
7 Apr 2021 11:04
Palenar schrieb:
The back panels of the Platsa modules are perforated or can be drilled, allowing for a flexible system of cable clips, cable ducts, or small shelves to be installed.
That is correct. Additionally, I recommend using specifically suitable clips for cable outlets to help organize the space efficiently. If needed, Platsa doors can also be fitted with magnetic strips to hang small notes or tools.
Palenar schrieb:
Keep in mind that the Platsa tabletop is not height-adjustable. Therefore, a good office chair is essential to accommodate individual sitting heights.
A height-adjustable office chair or, alternatively, an affordable sit-stand stool is a practical solution to partly compensate for ergonomics when the desk height is fixed.
Furthermore, adding lighting elements, such as LED strip lights under shelves, can provide comfortable illumination that makes working at the screen more relaxed.
If you need specific model recommendations, I can also compile a list of suitable Platsa components.
