ᐅ How can I securely mount Ikea Metod cabinets to drywall (gypsum board) walls?
Created on: 12 May 2022 08:37
laizet62Hello everyone, I want to securely mount my Ikea Metod kitchen cabinets on a drywall, but I’m unsure about the best way to do this. The wall is a standard drywall construction without additional reinforcement, and I know that drywall alone does not provide sufficient load-bearing capacity. My questions are: What types of anchors or fasteners are recommended for this? Should I definitely consider adding extra reinforcement inside the wall, and if so, what is the best way to achieve this? Are there any special mounting rails or accessories from Ikea or third-party suppliers that are suitable for this purpose? I definitely want to avoid the cabinets sagging or even falling off over time. For my planning, it would also be helpful if you could address the weight of the cabinets and the expected load capacity. Thanks in advance for your help!
Hello laizet62, your question raises a very important point, as drywall (gypsum board) walls can indeed be challenging when it comes to mounting heavy items like Metod cabinet units. Basically, drywall panels alone are not strong enough to securely support cabinets over time. Therefore, I recommend the following approach:
- First, check if there are wooden studs or metal studs behind the drywall. If so, you should mount the cabinets directly onto these, as this is always the most stable solution.
- If no load-bearing elements are accessible, it is possible to use so-called hollow wall anchors or toggle bolts, which distribute the load over a larger area of the drywall panel.
- Alternatively, reinforcement can be achieved by screwing an additional wooden batten onto the wall, which then serves as a mounting base.
- Ikea usually does not offer special rail systems for mounting on drywall, but there are universal mounting rails for kitchens that can be securely fastened to the wall.
The weight of a single Metod wall cabinet varies depending on size, but you can expect at least 20-30 kg (44-66 lbs). When the cabinets are fully loaded, the weight increases considerably. So, plan carefully how the load will be distributed.
My advice: If you have any doubts, have a professional help you with the installation or reinforce the wall. Safety comes first! If you want, I can also give you more detailed tips on screws and anchor types.
Hey laizet62, don’t worry, you can do this! I also mounted my Metod cabinets on drywall, and they held up really well. The key is to use the right anchors—I especially recommend toggle bolts. They grip the drywall firmly and support the weight reliably.
What worked great for me was attaching a sturdy wooden batten to the wall before mounting. This helps distribute the load over a larger area. Then you can safely hang the cabinets on the batten.
Don’t be discouraged—just take it step by step and always make sure everything is securely in place. And if you run into any problems, feel free to ask—together we’ll definitely figure it out! 🙂
Hello laizet62, I would like to explain the issue of load-bearing capacity on drywall (plasterboard) walls in more detail, as this is where most mistakes occur.
First, the construction type of your drywall is crucial: Is it a single-layer paneling on a conventional metal or wood frame, or is it a double layer? Especially with single-layer walls, standard anchors are often overloaded.
Here is a detailed procedure for a secure installation:
- Step 1: Determine the position of the stud profiles (usually spaced 60 cm (24 inches) apart). Fastening elements should ideally be placed directly into these studs.
- Step 2: If optimal access to the studs is not possible, I recommend installing an additional load-distribution panel (e.g., a plywood board, 18 mm (0.7 inch) thick) over the wall. Attach this panel to the existing studs using long chipboard screws. Then mount the cabinets onto this panel.
- Step 3: Use special hollow wall anchors with high load capacity, for example metal toggle bolts with load ratings of at least 40 kg (88 lbs) per fastening point.
It is important to always use at least two screws per cabinet side; four screws are ideal if the cabinet is wide. Only when the load is properly distributed can you avoid permanent deformation or even the risk of falling.
One last question: How wide and deep are your cabinets, and how heavily do you plan to load them? This will help me recommend specific anchor types for you.
TEBILO schrieb:
One final question: How wide and deep are your cabinets, and how much weight do you plan to load them with? This will help me recommend the appropriate type of wall plugs.Thank you, TEBILO, for your detailed reply! My Metod wall cabinets are 60 cm (24 inches) wide and 40 cm (16 inches) deep. I plan to store mainly dishes and some pantry jars in them, which adds approximately 15-20 kg (33-44 lbs) of additional weight per cabinet. The wall is made of a simple, single-layer gypsum board construction with metal studs. I haven’t measured the distance between the studs yet, but I will do that soon.
Based on this information, how would you refine your recommendation regarding wall plugs and reinforcement? Are toggle bolts with a load capacity of 40 kg (88 lbs) per fixing point sufficient if I use two screws per cabinet side? Or would using a plywood panel be a better solution to be on the safe side, especially since I want the installation to be durable over the long term?
Looking forward to your assessment!
