ᐅ How can I securely install IKEA Metod inner drawers?
Created on: 6 Feb 2019 09:13
kerutar
kerutar
6 Feb 2019 09:13
Hello everyone, I have a small project where I want to securely install the IKEA METOD inner drawers. I am looking for tips or advice on how to fasten the drawers so that they are not only stable but also function smoothly in the long term. I am interested in details on proper alignment, specific mounting points, any necessary tools, or tricks to avoid jamming or misalignment. Recommendations regarding screws, anchors, or additional materials to use would also be very helpful. How can I ensure that everything fits cleanly and is well adjusted without damaging the construction? Thanks in advance for your experiences and advice!
Roberta
6 Feb 2019 10:47
It is best to use the assembly kits provided by IKEA. The drawers run on built-in runners, which must be installed perfectly straight. It is important to tighten the screws firmly but not too much, to avoid damaging the material.
Ixvin
6 Feb 2019 12:09
Hello kerutar, I can help you with that! First, it’s important to precisely align the drawer fronts and the drawer slides. This is especially crucial with METOD-style units, as any misalignment can cause the drawer to stick or jam when closing. Make sure that:
- The drawer slides are installed perfectly parallel to the back panel of the cabinet.
- The screws are secured tightly enough to prevent movement but without damaging the wood.
- It’s best to pre-drill the holes if the wood seems solid to avoid splitting.
Adjustments after the initial installation are normal because the wood may still settle. I recommend a step-by-step assembly: first, install the empty drawer; then attach the front panel; finally, fully insert the drawer. This way you can check if the slides and front panel fit properly.
noge58
6 Feb 2019 14:26
I love these Metod drawers! 😃 For a secure installation, always work carefully and precisely to avoid any jamming. Important: Use a spirit level to align the rails; otherwise, you’ll have trouble opening the drawers! A tip from me: Invest in good screwdrivers, as they help the screws thread in better and prevent damage to the screw heads. Good luck, it will surely work out great!
pikin
7 Feb 2019 08:57
From a technical perspective, the secure installation of the METOD internal drawers mainly depends on the precise mounting of the drawer slides. The slides should be fixed with at least three screws per side to ensure stable load distribution. Make sure the screws do not overstress the material and use pre-drilled holes to prevent splitting. Additionally, using small spacers or washers can be helpful if there are slight irregularities in the front panel or cabinet body. For adjustment, the settings on the drawer fittings should be consistently used to ensure smooth operation. This prevents jamming or premature wear.
semuneo
7 Feb 2019 11:18
pikin schrieb:
To ensure smooth operation, the adjustment options on the drawer slides must be fully utilized.
I want to emphasize this again because, out of impatience, I initially didn’t fine-tune enough – which made things more complicated. Take your time with this step, even if the manual doesn’t highlight it much. Sometimes you need small corrections if the drawer moves well but sticks when opening. It can be frustrating, but patience leads to success here. The drawers are of high quality and respond well to careful installation.
