ᐅ How can I prevent IKEA Metod drawers from falling out?
Created on: 24 Mar 2018 18:07
sokau
sokau
24 Mar 2018 18:07
I have installed IKEA Metod drawers in my kitchen and I have a problem: when I pull the drawers out fully, the drawer boxes sometimes accidentally come completely out of the cabinet. I would like to find a way to mechanically secure the drawers or use simple tricks to prevent them from falling out when opened, while still keeping them easy to operate. It is important to me that the solution works without major modifications and is also durable in the long term. How can I secure IKEA Metod drawers against falling out? Are there any specific components or small technical aids that you would recommend?
Mufato
24 Mar 2018 19:32
METOD drawers usually have built-in ball-bearing slide systems with stoppers for the drawers. If your drawers come off, the stoppers may not be properly engaged. You can simply check the slides to see if the stoppers are correctly seated or if they shift slightly. Alternatively, there are inexpensive plastic stoppers or so-called drawer locks that you can install inside to prevent the drawer from being pulled out completely.
Sepele
25 Mar 2018 08:46
Regarding your concern about securing the IKEA Metod drawers against falling out, I’d like to offer a brief guide, as this issue is quite common with these drawer systems. Here are the main steps and tips:
- First, check whether the drawers have built-in stops on the drawer slides. These stops are usually small plastic tabs or metal hooks located at the front that prevent the drawer from sliding out completely.
- If these stops are missing or damaged, you can purchase replacement parts at a hardware store or IKEA that fit the Metod slides precisely.
- Another option is to install small stoppers yourself (e.g., made of rubber or plastic) attached to the inside edges of the drawer sides. Make sure the drawers still operate smoothly.
- Important: Before adding extra safety measures, verify that the drawer is correctly installed. Improper installation can also cause the drawer to come out easily.
- Sometimes it helps to clean and lightly lubricate the slides, as dirt or lack of smooth running can cause the drawer to not engage properly, leading to it falling out.
In short: First check the existing stops, then you can retrofit simple parts if needed. If you like, I can also provide tips on how to install such stoppers correctly.
JEREMIAH38
25 Mar 2018 15:13
I completely understand how frustrating it is when drawers keep falling out—especially when you have several items inside and everything ends up on the floor. I had a similar issue with my kitchen, and fortunately, I was able to solve the problem with a combination of small stops and a bit of caution.
I find this idea very practical. I installed a simple rubber buffer inside myself, which prevents the drawer from slamming shut too hard—and at the same time, it acts as a brake when pulling the drawer out.
If you’re unsure about how to do this best: You can also secure your drawers with a second small locking system that’s easy to install yourself—this is something I found in the accessories section at IKEA. If you want, I’d be happy to advise you in more detail or share my experience.
Louie
26 Mar 2018 10:54
Hello sokau, I would like to answer your question in detail because the issue of drawer security with IKEA Metod is quite common, and many users face similar challenges.
Basically, the Metod drawer slides are designed to prevent the drawer from falling out. However, it can still happen that the drawer is fully pulled out if the end stop does not function properly or an additional safety device is missing.
Here are some tips that might help you:
- Check the assembly: Often, the cause is a drawer box that is not hooked in correctly or a drawer slide that is improperly attached. Make sure everything is seated properly.
- Inspect the end stops: IKEA has special end stops for Metod drawers that prevent the drawer from being pulled out completely. These parts should be located at the front end of the drawer slide.
- Add security clips: There are so-called security clips or small plastic pieces that act as additional stoppers to prevent unintended removal.
- DIY stoppers: Some users attach small felt or rubber buffers inside the cabinet on the backwall of the drawer opening to stop the drawer from being pulled out entirely.
- Maintain the drawer slide: Clean rails and light lubrication can help ensure smooth operation and proper locking.
If you like, I can also provide you with a step-by-step guide on how to systematically approach fixing the problem. Just let me know if you need more details or explanations.
