ᐅ How can I add a soft-close mechanism to Ikea BESTA doors?
Created on: 6 Sep 2022 10:22
Timehdi
Timehdi
6 Sep 2022 10:22
Hello everyone, I am planning to retrofit soft-close mechanisms on the doors of my Ikea Besta TV cabinets to prevent the annoying slamming. My specific question is: What options are available to install soft-close hinges or dampers on the existing BESTA doors with minimal effort? It is important to me that no completely new hinges are required, but rather an upgrade solution that fits into the existing drill holes or requires only minor adjustments. Does anyone have experience with compatible systems or practical tips on what to consider when choosing—especially regarding the mounting method, material compatibility, and the soft-close function? Any recommendations on common brands or solutions that work well with BESTA would also be greatly appreciated. Thanks!
Garry
6 Sep 2022 12:37
Retrofitting a soft-close system on Ikea BESTA doors is possible but requires some preparation, as the original hinges do not have an integrated soft-close feature. There are two common approaches: - Either replace the hinges entirely with soft-close hinges specifically designed for BESTA – these usually match the same drilling pattern and are relatively easy to install. - Or install external soft-close dampers, which are small mechanisms screwed onto the inner cabinet or door frame to gently slow the door’s movement. When retrofitting the hinges, it’s important to note that the original drilling holes on BESTA are typically standard size, which makes fitting easier. Hinges with adjustable soft-close functionality are recommended so that the damping can be optimally set. Brands like Hettich or Blum offer compatible models with good quality that fit furniture like BESTA. Important: Check exact dimensions and drilling measurements before purchase to avoid unwanted drilling or modifications. In some cases, the slightly higher investment in completely new hinges is far more worthwhile than compromising with external dampers.
LOJOPAR
7 Sep 2022 09:45
Timehdi schrieb:
What are the options for installing soft-close hinges or dampers on existing BESTA doors without much effort?
I would like to share a brief guide that I successfully applied myself, including some tips on what to avoid.
1. Preparation: It’s best to carefully measure the door and cabinet and closely examine the hinges on the BESTA doors. Typically, these are standard cup hinges with a 35 mm (1.4 inch) cup hole diameter.
2. Hinge selection: I recommend using hinges from Blum or Hettich with integrated soft-close functionality that fits 35 mm (1.4 inch) cup holes (usually "Clip Top" type or similar). These are directly interchangeable.
3. Removal: Carefully remove the old hinges, paying attention to the screws and avoiding damage to the doors.
4. Installation: Insert the new soft-close hinges. Be careful when positioning them to use the existing drilled holes exactly and avoid any modifications. Test the soft-close function before fully tightening the screws.
5. Fine adjustment: Use hinges with adjustment options—height, lateral, and depth settings should be checked and optimized so the doors fit perfectly and the soft-close works smoothly.
Tips:
- Avoid cheap soft-close systems that do not allow continuous adjustment.
- Do not add extra screws outside the existing holes without prior inspection, as this can damage the doors.
- If possible, compare samples or datasheets before purchase.
Conclusion: For BESTA, completely replacing the hinges is the cleanest and safest solution; external retrofit dampers are usually a compromise and can negatively affect the appearance.
DEOLAU
7 Sep 2022 15:12
For soft close on BESTA, it is best to retrofit by replacing the hinges with suitable Blum or Hettich models that feature soft close. External dampers are usually impractical and not ideal for the appearance. The drill holes of the original hinges usually fit exactly.
Z
zarJody68
8 Sep 2022 08:17
Garry schrieb:
Hinges with adjustable soft-close functions are recommended, as they allow optimal damping adjustment.
This is a crucial point. Adjustable soft-close hinges are technically superior because they allow adjustments based on the door’s weight and size. Especially for the Ikea BESTA door models, precise tuning can extend the mechanism’s lifespan and prevent issues like irregular closing or sticking.
LOJOPAR schrieb:
For BESTA, a complete hinge replacement is the cleanest and safest solution
I agree with that. Alternatively, you can try third-party soft-close hinges, but it’s important to pay attention to quality and compatibility. Cheap solutions often lead to frustration and potential damage to the furniture. For those not wanting a full hinge replacement, it’s worth mentioning that so-called “retrofit dampers” exist that can be installed inside. However, these are generally less durable and require special installation, often involving drilling or screws that IKEA does not intend.
