ᐅ KALLAX doors always pop open when closing – are better hinges needed?
Created on: 4 Dec 2024 08:12
Sonfredric
Hello everyone, I have been having an issue with the KALLAX doors from IKEA for some time now: whenever I close the doors, they “pop” open slightly after a short while, even though the hinges seem to be installed correctly. This happens with both doors on a KALLAX 4x4 unit. I wonder if this is caused by the standard hinges used and if there are better, more stable alternatives that could prevent this problem? I would appreciate any tips on hinges that stay firmly closed and stable over time. Maybe someone has experience with alternative hinges or improvements that stop the doors from “popping” open? Thanks!
Davidleo
5 Dec 2024 11:07
Great topic! 🙂 I’ve experienced this myself and then switched to Blum hinges, which are much more durable. The opening and closing action is really smooth, and there’s no more “jumping” off!
If you’re feeling brave, give it a try! It really helped me a lot. And the best part is: you hardly notice that you’ve improvised. That’s what makes DIY fun! 😉
Nabla64
5 Dec 2024 11:45
Here is a brief guide for replacing the hinges on KALLAX:
1. Remove the old hinges: loosen the screws and take off the doors.
2. Check the old drill holes – they are usually 35mm (1.4 inches) cup holes, which is the standard size.
3. Obtain alternative hinges: for example, Blum Clip Top or Hettich Sensys; pay attention to the overlay dimension.
4. Adjust the hinges: if the drill holes fit, simply screw them in securely.
5. Adjustment: new hinges often have adjustment screws for fine-tuning height, depth, and lateral position.
6. Rehang the door and test the function.
Common mistakes:
- Screws too loose, which causes looseness over time
- Door panel not aligned precisely parallel
- Using incorrect drill holes affects stability
Following these steps ensures a better and more durable result.
Domau0
5 Dec 2024 13:22
Nabla64 schrieb:
Common mistakes: screws too loose, which causes loosening
Very important! Often, doors don’t misalign because of the hinges themselves, but because screws slowly loosen in chipboard or MDF material. This causes the spring to lose its tension.
[quote=Sonfredric, post: k5w1i5, member: XXX]Are there any recommended models that are mechanically more stable?
To answer your question directly: I recommend the "Blum Clip Top" series, which offers the right balance of spring force, durable mechanics, and easy installation, and is successfully used by many IKEA users.
Palenar
6 Dec 2024 07:54
I would like to add to the previous comments that the load and installation angle of the hinges play an important role.
The spring mechanism of a concealed hinge is designed for a specific closing force. If the angle between the door and the cabinet is slightly off, the spring can overstretch or compress, which increases the risk of it popping out.
It is also important to consider whether a door might expand or contract slightly due to moisture or temperature changes, causing the material to warp. This can lead to irregular stresses that stronger hinges may not fully compensate for.
Sometimes, the best approach is a combination of carefully adjusting the door alignment, tightening the screws, and upgrading to higher-quality hinges.
Maybe you could check if the doors are hanging slightly crooked or if there are any pressure marks on the hinges?
Sonfredric
6 Dec 2024 09:18
Domau0 schrieb:
I recommend the "Blum Clip Top" series, which has just the right combination of spring tension, durable mechanics, and easy installation.
Thank you all, I will follow the advice regarding Blum hinges. I was a bit concerned that the installation might be somewhat complex, but with the tips from Nabla64, I feel well prepared.
The suggestion to check the screws is also very helpful—I will pay close attention to this and carefully inspect my doors for any warping or play.
This topic has been very helpful, and your tips on warping and spring action give me a good starting point. I’ll get back to you once I’ve tried more.
