Hello everyone, I am planning to refinish my Ikea Metod kitchen cabinets myself to enhance their appearance and create a custom design. I am particularly interested in the best way to prepare the surface, recommended materials, and whether there are specific techniques to effectively work with the MDF surfaces or laminate coatings on the doors. Has anyone had experience with sanding, priming, or painting these cabinets? Or is it possible to remove the laminate and replace it with a different surface? I would be very grateful for tips on tools, products, and each step of the process to achieve a professional result without needing expensive workshop equipment. Additionally, I would like to know if there are any special considerations regarding the material of the Metod cabinets that should be kept in mind. Thank you in advance for your help!
praWarre6928 Mar 2021 08:22tanru schrieb:
Can we take a closer look at the material composition of the current doors? Great idea! Two years ago, I simply painted over my Metod doors with bonding primer and roller-applied lacquer. It worked really well, even though the laminate wasn’t removed. Maybe people don’t like peeling off laminate here—it’s like pulling off a plaster—exciting but often unnecessary ;-) If you really want to change something, it’s better to sand, prime, and go! In the end, it’s about the appearance, not getting new furniture.
Thanks for the tips so far! The doors are actually foil-coated on MDF substrate panels, which was also confirmed in the IKEA material test. I no longer find the foil finish appealing, so I want to apply a matte, slightly textured paint myself. The idea is to completely remove the foil and then prime the MDF panel again. However, I’ve read that removing the foil carries some risk and the panel can be damaged. Are there gentler alternatives to prepare the foil surface so that a new paint can be applied and adhere well? Or will I actually have to replace the doors entirely in the end? I’m currently working with sandpaper and primers and have looked at replacement fronts at IKEA, but I find the prices quite high. I would appreciate concrete recommendations and safety tips, especially regarding foil removal!
leoan5 schrieb:
Removing the film involves some risk and the panel may be damaged. That’s correct, the thin MDF panel can tear or fray when removing the film. If appearance is your main concern, applying a matte primer over the sanded film is a better option. Sand it well beforehand with 200-320 grit sandpaper and degrease thoroughly. Alternatively, you can use a fillable plastic primer to even out any unevenness. Afterwards, paint with a matte acrylic lacquer suitable for melamine/MDF. This way, you can keep the film intact and still create a fresh look. Completely replacing the doors is only worth it if stability or functionality is impaired.
leoan5 schrieb:
Are there gentler alternatives to prepare the foil so that a new paint can be applied and adheres well? Another method is to use adhesion-promoting primer sprays specifically designed for difficult plastic surfaces. These improve the paint’s adhesion even on smooth foils. The foil is not removed; instead, the pre-treatment enhances its adhesion. Applying several thin coats along with light sanding between layers results in a very good outcome. This can save you a lot of work and minimize the risk of damage.
