ᐅ How can I quickly dismantle IKEA Metod kitchen cabinets when moving?
Created on: 14 Jul 2020 10:32
RILEO
RILEO
14 Jul 2020 10:32
I am planning to move soon and would like to take my IKEA Metod kitchen cabinets with me. Since I already know that the furniture needs to be completely disassembled for transport, I am looking for a way to take the cabinets apart relatively quickly and without major damage. I imagine that the doors, shelves, and possibly the drawer slides require special attention.
My specific question is: How can I disassemble IKEA Metod kitchen cabinets during a move quickly and efficiently while keeping the parts undamaged and ensuring the reassembly goes as smoothly as possible? Do you know if any particular tools are absolutely necessary or if there are special tips to protect the screw holes?
I look forward to your experiences and advice!
bijo54
14 Jul 2020 10:57
RILEO schrieb:
How can I disassemble IKEA Metod kitchen cabinets quickly and efficiently during a move, ensuring that the parts remain undamaged despite the speed and that reassembly later goes as smoothly as possible?
Loosen the screws one by one in a systematic way, preferably using a cordless drill with the appropriate bit. Remove doors and shelves first. Collect screws carefully. Avoid using force, as this can cause the panels to chip.
Lilygla
15 Jul 2020 08:45
RILEO schrieb:
How can I disassemble IKEA Metod kitchen cabinets quickly and efficiently during a move, ensuring the parts remain undamaged despite the speed and that reassembly later goes as smoothly as possible?
The topic of disassembling IKEA Metod kitchen cabinets is more complex than it might seem at first because there are details involved that usually become clear during assembly.
My advice:
- Preparation: Take time to carefully inspect the cabinets beforehand and identify all types of screws (wood screws, cylinder head screws, cam fasteners, etc.). A well-organized screwdriver or cordless drill with various bits is essential.
- Doors and fronts: Start by removing the doors, as they are usually hung on special clip-on hinges. Often there is a fixed cover cap that you need to gently remove with a small screwdriver to access the screws.
- Interior components: Remove all shelves, which are usually just pressed in or resting on dowels and can be taken out quickly.
- Drawers: Metod drawers often have running rails. Pull the drawer completely out to reveal the locking mechanisms on the rails. These are usually small levers that you must press simultaneously to release the drawer.
- Protect panels: To avoid damage, use the appropriate torque setting on your cordless drill and work slowly. Don’t force screws that seem stuck; instead, check carefully whether a connector piece is blocking them.
One more note: It’s best to label parts either numerically or with colored stickers to speed up the reassembly. I sometimes write the screw or part numbers on small pieces of paper and tape them to the components.
Feel free to ask if you have a specific cabinet type or accessories, as that can affect the procedure.
Tevin
16 Jul 2020 14:18
Lilygla schrieb:
Label the parts with numbers or colored stickers to make reassembly faster.
That’s a great tip and will save you a lot of time later, especially when dealing with multiple cabinets.
Additionally:
- Use a magnetic screw container or small bags for each cabinet or drawer to keep track of screws.
- When dismantling, you can carefully pry open tight joints using a flat spatula or a thin plastic lever.
- Pay special attention to the hinges and make sure to remove all mounting screws completely, otherwise the door might get damaged during removal.
As for tools, usually a cordless electric screwdriver with a bit set is sufficient, along with a small Phillips screwdriver for fine adjustments and a small tool for the drawer slide mechanism. Depending on the cabinet type, hex keys (Allen wrenches) might also be needed.
If you want, I can also prepare a short checklist for you.
