ᐅ How can I protect IKEA Platsa furniture for outdoor use?
Created on: 11 Oct 2015 09:17
marpe69
marpe69
11 Oct 2015 09:17
Hello everyone! I am planning to use some IKEA Platsa furniture pieces on my terrace but want to protect them as best as possible from weather exposure since the wood and materials are not specifically designed for outdoor use. My question is: What effective methods do you know to protect the furniture for outdoor use against moisture, sunlight, and other environmental factors? I am particularly interested in tips for surface pretreatment or sealing, suitable paints or wood preservatives, as well as practical advice for maintenance during the season. Are there any specific experiences or DIY solutions to significantly increase the durability of the Platsa modules outdoors without altering their appearance too much? Thanks in advance for your insights and recommendations!
Rosan
11 Oct 2015 10:04
It’s best to use weatherproof stain or polyurethane varnish. Don’t forget to sand beforehand; that will help the furniture last longer. Most importantly: avoid direct contact with ground moisture by using feet or wooden slats as a gap.
biel33
11 Oct 2015 11:29
marpe69 schrieb:
My question is: What effective methods do you know to protect garden furniture from moisture, sunlight, and other environmental factors?
I’m familiar with this issue – I’ve had similar concerns myself. Actually, Platsa furniture isn’t designed for outdoor use, so even well-sealed pieces will eventually suffer. I always found it challenging to strike the right balance between protection and preserving the typical IKEA look. Your idea to pre-treat the furniture makes a lot of sense. For me, a combination of wood oil followed by a thin coat of clear varnish worked well to keep moisture out.
Additionally, I would definitely recommend keeping the furniture under some kind of cover, like a porch or at least a tarp, to protect it from heavy rain. Regarding maintenance, I’ve had good results with regular visual inspections and refreshing the wood protection every few months. This way, you don’t feel powerless when the weather changes suddenly.
It’s a fine line, but doable. What are your plans: to keep the furniture outside permanently or only seasonally?
marpe69
11 Oct 2015 12:07
biel33 schrieb:
What are you planning: to leave it outside permanently or only seasonally?
Good question! I plan to use the furniture mainly seasonally, so to keep it outside from spring to autumn, but not in winter. Still, I want to prevent the wood from deteriorating too quickly due to moisture or UV exposure, and I’m concerned about fading or swelling causing problems. The idea of applying clear varnish in addition to wood oil sounds interesting. Do you have a brand or product you could recommend? I also don’t want the surface to look too shiny or artificial after treatment – more like preserving the typical appearance of Platsa.
Thanks also for the tip about a tarp or canopy; I hadn’t thought of that before, even though it makes perfect sense.
bareynaldo
12 Oct 2015 15:53
biel33 schrieb:
I always found it difficult to find the right balance between protection and the typical IKEA look.
What exactly is this balance supposed to be? Using furniture that clearly isn’t made for outdoor use outside and at the same time hoping it stays looking good without any consequences? That’s kind of contradictory.
If you use Platsa in the garden and care about the appearance, you should be honest: it will suffer, no matter what sealant you apply! Either you accept rust, swelling, or discoloration on the surface, or you buy furniture designed for outdoor use – and yes, that usually costs more in the end.
I think it’s important to be realistic here. I understand your concern about high-gloss plastic surfaces, but transparency and maintenance become impossible when the furniture is kept outside, especially with inexpensive particleboard pieces like Platsa.
Just a thought: wouldn’t it be better to focus on furniture that can withstand the weather instead of trying to fix things with varnishes and such? That way, you’ll save yourself a lot of trouble.
