ᐅ How can I protect Ikea Hemnes furniture from bumps and impacts?
Created on: 24 May 2024 18:37
Enrico43
Some time ago, I bought several Ikea Hemnes furniture pieces because they fit very well with my interior style. However, I am concerned about the durability of the surfaces, especially regarding possible impacts or minor damage from everyday use. How can I most effectively prevent the Hemnes furniture from being damaged by bumps or accidental collisions with other items? Are there any specific protective measures you would recommend, for example, for protecting the edges or surface? I am particularly interested in practical, long-lasting solutions that preserve the furniture’s charm without being too noticeable or negatively affecting the feel. Thanks for your tips!
Lucien
25 May 2024 11:15
Jukin schrieb:
Surface protection: You can apply a thin protective film made of PVC or polyurethane to the surface. These films are clear and protect against scratches, moisture, and minor impacts.
An additional note: When choosing a protective film, make sure it is compatible with painted wood surfaces like those of Hemnes. Some films may leave residues or cause discoloration if used long-term. There are films specifically designed for furniture that either do not use adhesives or use adhesives that can be removed without leaving any residue.
It is also helpful to sand down the edges before applying the film to soften sharp corners and reduce the risk of impact damage.
When done correctly, this can significantly extend the lifespan and maintain the appearance of the surface.
Ramon4
25 May 2024 15:58
sanjon schrieb:
I would recommend simply using transparent edge protectors.
That’s a good approach. Additionally, I would like to point out that when applying edge protectors to Hemnes furniture, you should be careful to avoid trapping moisture, which could cause damage later on.
Also: If the furniture is moved frequently, soft casters with a braking function are recommended. These can be easily installed and help reduce wear on the furniture.
These measures are simple to implement and improve durability in everyday use.
RENMA
26 May 2024 07:03
pikin schrieb:
For surfaces, special self-adhesive furniture films are a good alternative that provide protection and are visually inconspicuous.
I would like to add a note regarding material compatibility and aesthetics:
- High-quality furniture films with a polyurethane coating not only protect against scratches and impacts but are also UV-resistant and help prevent discoloration.
- Their application requires a very smooth surface and thorough preparation, otherwise air bubbles or peeling may occur.
- In the long term, these films are recommended if the original character of the furniture is to be preserved.
For Ikea Hemnes furniture, I suggest making a careful selection and, if necessary, seeking advice from a specialist retailer to avoid damage when removing the film.
